Replacing Ribbon Flex with CAT5?
  • Spode
    • Dec 2010
    • 41
    Long story short - I have a master/slave inverter setup and I don't have the flex ribbon cable to connect them.
    The ribbon is one of those super flat, 11-pin connectors which apparently operates at high temperatures (it sits over the back of the panel - so I imagine it gets pretty hot there).
    The inverters have quite large copper circles/pads that connect to each pin of the connector - I assume so the engineers can easily measure readings on those pins?
    So I soldered some CAT5 to the connections - as it turned out only 8 of the pins were in use, and then 9th was a ground, so I just used a bit of speaker wire.
    I used a longer piece of cable than the original ribbon, so I could route it differently (so it didn't get as hot) and the outcome was that it didn't work - neither inverters switched on.
    I'm wondering :
    - Would the extra resistance of the longer cable, and thicker cable screw things up?
    - Would the twisted nature of CAT5 screw things up?
    Is there another solution to this problem - such as a cheap way of buying a generic flex ribbon?
  • Spode
    • Dec 2010
    • 41
    Re: Replacing Ribbon Flex with CAT5?
    Just thought I'd add - ribbon cable was the wrong terminoloy.
    http://en.wikipedia.org/wiki/Flexible_flat_cable
    It's one of these - so a lot thinner than the copper in my solid core CAT5!
      Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
      This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
      09-07-2024, 07:20 AM
      09-07-2024, 06:38 AM
