Samsung 42" HP-T4254, Was Clicking now another problem
  • Seether
    • Nov 2010
    • 3
    Ok, Ive found the clicking issue and it seems to be the X-Sus board, because when power is removed from it, the Tv will come on and stay on.
    Picked it up out of my local dump , Guy was going to throw the TV away and I screamed I would take it lol, Think I gave the poor man a heart attack.
    Now heres what gets me without the X-Sus their is no sound nor a picture that I can see. There is a large black blob in the screen that will slowly fade away to snow if left on for a long time and has a pink hue that also fades. Now if you unplug all but 1 of the plasma screen plugs (lack of knowledge their) that 1 line will come on automatically clear as well...Snow lol.
    The Plasma screen is not the problem I have checked each line individually and each line will come on perfectly if its the only one plugged in. My question is will the X-sus board when I get a new one remedy this (this problem hapens while the x-sus is unplugged)
  • Seether
    • Nov 2010
    • 3
    Re: HP-T4254, Was Clicking now another problem
    Its a Samsung HP-T4254
    • PlainBill
      • Feb 2009
      • 7034
      Re: Samsung 42" HP-T4254, Was Clicking now another problem
      Standard answers:
      1. Pictures are always good
      2. Standard technique for detecting this type of problem is to unplug power to sustain cards one at a time.
      3. A bad X-Sus will cause strange colors on a plasma screen.
      4. Terms like 'large blob' and 'plasma screen plugs' are little help. There are LOTS of connections to a plasma screen. Refer to #1.
      5. Service manual can be found here.
      PlainBill
      • Wizard
        • Mar 2008
        • 2296
        Did you unplug that power cable from the leftmost board? That's called YSUS board.
        Check the small chips on the Y-buffer boards that they are not burned out (cratered).
        Photos and full model number, and model number of panel sticker.
        Cheers, Wizard
        • Seether
          • Nov 2010
          • 3
          Ok yes I did, There are 6 connections for the Screen coming off the Y Buffer, If I leave all 6 plugged in on the Screen all I can see is a huge black box that will slowly fade away, I will add pictures soon
          The X-sus is the problem board I was just wondering should I order a Y-Buffer when I ordered the X-sus
            09-07-2024, 05:50 AM
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
