Pantum P2502W Toner Reset Chip help
    Re: Pantum P2502W Toner Reset Chip help
    Originally posted by dexrex View Post
    Hello, I have been trying somehow to make the pantum p2500w printer work without the chip that the toner comes from the factory.
    Is there any way to edit the firmware of these printers? Or someone who knows the method to obtain the firmware?
    What is your board model ?
      Can someone modify my extracted firmware. I used a spi programmer to read the chip.
      Btw this a early firmware
        I believe it's version 1.1.3.4. What tools do I need to decompile this firmware?
          First you need to extract/decompress the firmware using offzip.
          offzip.exe -a "pantum toner empty.bin"
          You can then disassemble the generated "00020120.bin" ELF file with Ghidra.
            Thanks for the help, I was able to extract the bin file and working on getting ghidra up and running.
            I found NoChip_CA2J000228_P2500w_1.2.9.7.fwr and downloaded the file.
            Do you know where the printer ID is stored in the fwr file. I was hoping to just use hexedit and overwrite my printer id in the this modified file.
            BYW I can't send you a private message
              File attached, Chipless firmware just need to figure how to modify for your printer ID.
                BASE64 decode that string and you get "CA2J000228P2500w".
                  Thanks once again, I think I got it.. Maybe during weekend will attempt.
                    I can help, I need an exact model of the board that is written on textolite.
                      Overwriting the serial number in base64 will not help, the rest of the contents are encoded by the firmware program.
                        Kado09, take a look at post #10 on page 1.
                        I posted pictures of my board long time ago.
                        Thank you all for your help, I hope this also helps others.
                          Try flashing this in spi flash.
                            Just tried it, it keeps flashing green led2.
                            Also it has a wifi password setup
                            also tried test print and it gives error message.
                              Need help with modding printer id in my backup bin file.
                              I tired to change to CA2J000228, but after flashing it reads AA2A000000.
                              I attached original and modify file.
                                There is a checksum somewhere I think.
                                  Do you think the printer id is also stored on another chip also? or only in firmware
                                    Probably not. You can change the serial number via USB by using the AclSetSerialNumber command. I also checked the code that writes the serial number to the flash chip, and it does calculate a checksum.
                                      Try this checksum. It should be correct.
                                        Thanks that let me flash fwr, now the problem is that takes flash and then bricks
                                        printer, both leds turn off and printer has no power.
                                        try two different fwr's one with 3.2.2.8 firmware and 1.2.9.7 fwr both not work.
                                          Just went back to backup firmware bin, now printer is printing!! it's say 35% used.
                                          Tried covering chip and won't print but now have 35% used and able to print.
                                          I made image backup and tried again the fwr chipless firmware and the printer bricked.
                                          Just to confirm it was not a hardware issue, I upgraded firmware through pantum tool and it updated my firmware no issue.
