Macbook Air A2337 Schematic & SilkScreen – 820-02016 Schematic & SilkScreen (Provisor
    Looking For 820-02016-A boardview BRD file.
      Originally posted by d0gan View Post
      Re: Macbook Air A2337 Schematic & SilkScreen – 820-02016 Schematic & SilkScreen (Prov
      Thank you - Great work
      Forget any letter on the end, there is only one 820-02016 for M1 Air
      See post #15 by whizkidz in this thread.
      Board is bvr not brd so use Flex Board view or Open Board View (some versions check with Piernov) to open bvr
      My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
        Thank you
          Thanks a lot brother 🙏
            Just discovered this today. Working on a liquid damaged board, and cleaning up corrosion around UC300. The pin numbering is back to front in the schematic in the schematic for RC321, hence why its wrong on the boardview. I will refer to the pins as they currently are on the boardview.
            CC328 pin 1 connects on the board to RC321 pin 1 not pin 2 (the bottom of the resistor, not the top). RC321 pin 2 connects to UC300/22 and CC329 pin 1.
            CC332 also back to front on the pinout too
              R5263 is also back to front on pinout
                Best to tag whizkidz seeing as he is the kind person tot made the boardview. I don't think that he can fix the schematic but he should be able to fix his boardview after confirming your findings. Also I am pretty sure that the boardview is generated totally independently of the schematic. The schematics are always leaked from Apple but sometimes people like whizkidz are smart enough to generate a boartdviw by mainly careful inspection of the logic board.
                  test
                    Thank you so much for all the work
