received this board with dc jack with a huge hole on the DC in 19 pin , so rmoveed everything and with the dremel have cleaner all the center burned hole , for i can have to the entire internal layer without touching each outher( it was shorting GND to vcc) not anymore , all good , cleaned board all layer have they mm os diference from each outhers , sodlered VCC on top and bottom VCC line , but still not having VCC in some parts , there is a main VCC line netween layers that feed rest of the circuit , so i would like to have the schematic for i can follow and now were i can solder and inject the 19 volts since dc in . so if anyonie have this schematic or can inform me wich is the first FET or fuse or whatsoever component after dc in i apreciate it . thk in advance
Hey guys , got a problem and need ASUS N71VN schematic
