Thinkpad T440p dead after bios flash
  • ikarusx3
    • Nov 2022
    • 3
    I have a Thinkpad T440p and it has severe connectivity issues. So to install a different wifi card i wanted to remove the whitelist and got me a programmer with bios clip.
    This is what i did so far:
    - Laptop was working
    - bios chip is winbond W25Q32FV, 32Mb, was detected correctly by programmer
    - Dump bios file 2 times, comparing and checking for FF FF, this worked well, all dumps are the same (attached)
    - following this: https://notthebe.ee/blog/removing-the-wifi-whitelist/
    - modified the dump, signed it
    - flashed back
    Then, when inserting battery and powering up, the devices does this:
    - Power LED lights up, fan spins up and stops again. After 5 seconds, LED flickers and fan spins up and stops again. No beeps, nothing displayed, repeats until battery is removed. Disconnecting cmos battery and discharging did not help.
    Flashing back original dump does not change anything, still unresponsive. I also extracted the original 2.56 bios from the lenovo update package and flashed it, same result.
    I'd be very happy for any suggestions to revive the device, the flash chip seems to be fine, flashing and verification is always successful.
  • Niccolò Banchi
    • Nov 2024
    • Italia
    - flashed back
    Hi, same here. Did you manage to solve it?
    • ikarusx3
      • Nov 2022
      • 3
      Unfortunately, no. I ended up getting a new mainboard for cheap and selling the machine.
      • Maik1974
        • Dec 2024
        • 6
        • Deutschland
        Hi, is there anything new? I have the same problem. T440p bios backed up and then patched. Patch installed. Since then the following error occurred: As soon as the power cable is connected, the fan starts rotating briefly, stops for a few seconds and then rotates again for about 5 seconds. The whole thing in a continuous loop. The power switch lights up permanently. This only stops when you remove the battery or pull the power plug. The same error pattern with every bios I play on it. This error occurs even if the BIOS chip is empty. Would be grateful for an answer. And yes, I have already freed three Lenovos from passport locations using the autopatcher. So actually I know how it works.
        • what_1282105
          Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
          by what_1282105
          Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
          02-14-2025, 07:27 PM
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
        • abhorsen
          Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
          by abhorsen
          Hey guys,
          Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
          Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
          Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
          07-06-2023, 10:22 AM
          Lenovo ThinkPad T440p Notebook T Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad T440p Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T440p boardview and T440p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
          09-06-2024, 06:58 AM
          09-06-2024, 06:51 AM
