hi i need danl9mb18f0 rev f Bios & it8987 io dump
  • tugrul63
    • May 2015
    • 94
    • türkiye
    hi
    ı need danl9mb18f0 rev f it8987 io dump
  • x-tuner
    • Jun 2014
    • 3
    • Kadıköy
    Re: excalibur g7k danl9mb18f0 rev f it8987
    Originally posted by tugrul63
    hi
    https://dosya.co/kxck3ge52grx/ITE.bin.html
    https://dosya.co/09dgu546ybz8/excali...k_ite.bin.html
    Quanta NL9 KB_pins=24 PD0=24 PD1=23 PD2=22 PD3=18 PD4=16 PD5=15 PD6=12 PD7=9 BUSY=7 STB=21 AFD=20 INIT=19 SLIN=17 KSI4=14 KSI5=13
    • ismailakyoltr
      • Mar 2015
      • 101
      • TURKEY
      hi
      ı need danl9mb18f0 rev f bios amd it8987 io dump thanks
      • peste
        • Dec 2016
        • 12627
        • ROMANIA
        Re: hi i need danl9mb18f0 rev f Bios & it8987 io dump
        Originally posted by ismailakyoltr
        hi
        post the full name and model of the laptop and the original bios
        • ismailakyoltr
          • Mar 2015
          • 101
          • TURKEY
          casper excalibur G7K ... motherboard : MODEL : NL9 DANL9MB18F0 REV F
            • 20665
            see post #2
            • ismailakyoltr
              • Mar 2015
              • 101
              • TURKEY
              yes i saw this thread but the links are dead
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
