Lenovo ideapad 5-14alc05
  • than_22
    • Sep 2017
    • 53
    • philippines
    Can someone help me fix my bios dump..
    laptop no display
    boardcode FLMA0 LA-J701P Rev 2.0
    AMD processor
    thank you in advanced
  • hoaca388
    Badcaps
    • Jan 2022
    • 12400
    Re: Lenovo ideapad 5 14alc05
    laptop no display
    AMD processor
    ideapad 5-14ALC05 Laptop - Type 82LM - 82LM002UPH
    • than_22
      • Sep 2017
      • 53
      • philippines
      thank you,, your file is tested,, more power ,, laptop brings back to life
      • hoaca388
        Badcaps
        • Jan 2022
        • 12400
        Yeah hooo !!!!
        • kostinqo
          • Sep 2022
          • 5
          • Slovakia
          Lenovo ideapad 5-14ALC05 BIOS
          Hello, I have a problem with removing the password from the BIOS dump. I bought a laptop with password protected BIOS (ideapad 5-14ALC05 Laptop - Type 82LM - 82LM008VCK) board FLMA0 LA-J701P Rev. 2.0 with Ryzen 5 5500U. Using the CH341A programmer, I made a bios dump from the Winbond W74M12JWSIQ bios chip (attached). But now I'm stuck on how to find the bios password and how to remove it. Can anyone help me with the removal or upload a clean bios for this laptop model?
          Thank you in advance for any help.
            • 22084
            bump
            • kostinqo
              • Sep 2022
              • 5
              • Slovakia
              any help ?
                • 22084
                Originally posted by kostinqo
                any help ?
                Can you post the laptop serial number. Comparing your backup with the one at post #2 they are very different,both are supposed to be Type 82LM. Is there another bios chip on the board ?
                • kostinqo
                  • Sep 2022
                  • 5
                  • Slovakia
                  It is possible because ideapad 5 has 3 versions of motherboard rev.01 rev.02 and rev.03. The first board had a regular BIOS chip W25Q128JWSIQ, my rev.02 board has a chip variant marked W74M12JWSIQ. It's basically the same chip with some extra protection (which doesn't have to be used, as in this case). The BIOS uploaded above in the thread is probably from the version of the board that has the original W25Q128JWSIQ chip. The SN of my laptop is MP1ZRCVR.
                    • 22084
                    any help ?
                    try this one
                    • kostinqo
                      • Sep 2022
                      • 5
                      • Slovakia
                      try this one
                      Sorry for the late response, but I didn't have time to test. I flashed the BIOS you uploaded. The password was removed, the system also seems to be working, but I want to ask. Is there something I'm missing in the bios, or do I have all the necessary information there?
                      • dimis7
                        • Feb 2011
                        • 20
                        Can someone help me fix my bios?
                        Not sure if the bios is the problem but is the easiest to check.
                        Symptom is black screen with backlight on
                        ideapad 5 14ALC05
                        s/n: MP1ZTWVD
                        MO: MPNXB14130AD
                        MTM: 82LM005CGM
                        main board FLMA0 LA-J701P REV 2.0
                        Thank you.
                        • peste
                          • Dec 2016
                          • 13721
                          • ROMANIA
                          ideapad 5 14ALC05
                          s/n: MP1ZTWVD
                          MO: MPNXB14130AD
                          MTM: 82LM005CGM
                          Thank you.
                          ret post#11..
                          https://www.badcaps.net/forum/showth...hlight=15ALC05
                          • dimis7
                            • Feb 2011
                            • 20
                            Originally posted by peste
                            Thanks.
                            Mine is 14ALC05 not 15ALC05. Same motherboard?
                            Also this file and all files on this thread are very different from my backup.
                            Are these files suitable for flashing directly to the chip by using external programmer or are only used for software flash?
                            • peste
                              • Dec 2016
                              • 13721
                              • ROMANIA
                              Thanks.
                              Bios extracted from Lenovo site update for
                              Ideapad 5-14ALC05 Laptop - Type 82LM
                              write the content directly to the chip...
                              • dimis7
                                • Feb 2011
                                • 20
                                Thank you.
                                I will give it a try later today.
                                • dimis7
                                  • Feb 2011
                                  • 20
                                  Didn't work.
                                  Laptop has a hardware issue.
                                  +5VALWP rail is missing...
                                  • Frostya
                                    • Sep 2023
                                    • 4
                                    • Armenia
                                    Hello!
                                    Asking for help!
                                    Ideapad 5-14ALC05 Laptop AMD
                                    Type: 82LM00A6RK
                                    Board: FLMA0 LA-JP01P rev: 2.0
                                    Serial: MP20KT17
                                    No screen after BIOS upgrade.
                                    BIOS: winbond 74M12JWSIQ
                                    Try to read it by several types of programms by CH341A programmer, and they all gave different result.
                                    1. How to read 74M12JWSIQ correct?
                                    2. Please, take look to my already readed files.
                                    Thank you!
                                    • peste
                                      • Dec 2016
                                      • 13721
                                      • ROMANIA
                                      Originally posted by Frostya
                                      Hello!
                                      Asking for help!
                                      Type: 82LM00A6RK
                                      Serial: MP20KT17
                                      Thank you!
                                      it's not good, you must have the same result.. remove the bios chip from the board before reading or writing, if you don't have anything to remove the chip, stick wires between the programmer and the chip.. watch a video here.. use one of these programs..
                                      https://www.badcaps.net/forum/showpo...6&postcount=10
                                      https://www.badcaps.net/forum/showpo...04&postcount=7
                                      https://www.youtube.com/watch?v=DWWigscuQDY
                                      • Frostya
                                        • Sep 2023
                                        • 4
                                        • Armenia
                                        Sorry, guys.
                                        Board has short circuit in 1,8 power line.
                                        It's not a bios.
                                        One of the indutor became too hot. It has strange voltage: 0,846 from one side and 0,766 from other.
                                        Heat pipes hot too.
                                          Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-07-2024, 05:20 AM
                                          Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
