HP BIOS unlock tool
Re: HP BIOS unlock tool
Originally posted by black0hackers View PostStill has bios pasword peste!Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by black0hackers View PostSorry, here is orginal fileDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by tiamoface View PostHi Gents,
Can you help please with HP EliteBook 840 G6 bios password removal?
Tried to remove and soldered chips back on the motherboard but now just caps lock always on and blank screen.
Attached 2 original dumps 16mb wson-8 and 32mb.
Thanks in advance!Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by jyg06 View Posti just bought a HP Probook 645 G2 with the bios locked with unknown password from seller, can you help me?
HP PROBOOK 645 G2
N° série 5CG7112N0S
Version du BIOS : N77 Ver. 01.07 - 11/01/2016
Merci
.Last edited by SMDFlea; 03-08-2021, 10:34 AM.
Originally posted by SMDFlea View PostUse a hex editor, compare the files in this thread to see where the edits were made then you can remove your own password - https://www.badcaps.net/forum/showth...&highlight=645 .Alternatively you can try the HPUnlocker at post #1 ,make sure you make a good backup first.
I would like to have the tutorial to do it because I am a little lost and this without having to unsolder the bios chip that I am unable to do.
Good morning all,
I received the eeprom programmer (EZP2019) and its software. All for a few euros including postage and it works extra. On the other hand I did not succeed in having a reliable dump with the clamp (with or without charger, with or without capacitance on the power supply (3.3uF and 100nF wired to the shortest (very close to the chip not on the clamp))).
So I unsoldered the chip by making myself a piece of copper (end of pipe modeled with the pliers) to have a thermal contact on the 8 pins at the same time and fixed on my soldering iron (80W minimum). After laborious heating, it was perfect. Desoldered and recovered with tweezers in 10s.
The chip on the adapter (zero insertion force) then multiple readings (with the EZ2019) to compare them with each other (Compare function of HxD). No differences on the ten reading of the chip. There, the reading is reliable.
Drag / drop onto the magic program (A BIG THANKS to RethoricalCheese) and a new unlocked bios is available.
3 successive erasures to be sure and reprogramming of the chip with the EZ2019.
And multiple rechecks.
Between reading, erasing and reprogramming, I did not touch the chip in the socket at zero insertion force in order to be sure all contacts were safe.
Re-solder the chip onto the PCB with a soldering iron and you're done!
Start and there, the magic happens. Everything works perfectly and goodbye damn password.
Thank you all for this very, very informative thread.
Didier.
Didier.
Originally posted by grzesiek3108 View PostProbably 3V , but you do not damage chip if its 1.8V (at least i never did) just programmer wont recognize it.
@RethoricalCheese Thx again for explain. I used try HxD when ive gote several SMC.bin files delivered from Hp support to figure out how to create it for myself, but never did
Confirmed : Probook 650 g1 i5 cpu, Desolder, puted on EZP, read bios .bin, just drag and drop .bin dump on your .exe, erase chip and write new created .unlocked.bin
Works great.
I also have an old probook 650 G1 with a blocked admin password.
Would you mind sharing your file with me?
Thx
ThxDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Thx
