Extract bios password from EliteBook 840 G8 Bios dump, possible?
    I tried many things and the device did not boot
      you need main bios or the ec
        EC
        MX25L25673GZ4I-08G _ 25R256JVEQ
          Originally posted by marc_ytos
          Greetings, I hope someone can help me remove the password from the bios, my board has number 6050a3216701-mb-a01, serial number 5CG23614S8, the model is elite book 850 g8, apparently it shares a motherboard with Hp Zbook Firefly, that's why I'm posting here, I hope not to fall into any infringement, thank you, I hope for your help.
          post the other chip bios and post it in hp elitebook 850 G8 thread
            This device has SWAT lock
            Hp Elitebook 840 G8
            Device Freeze -78324
            S/N : 5CG2274BT3
            Prod Id: 509H3UC#UUF
            Please send me unlock for my dump
              Hp Elitebook 840 G8
              S/N : 5CG2274BT3
              HP EliteBook 840 G8 Notebook PC (509H3UC)
              Become a Badcaps supporter
              Thanks to all supporters.
                I already flashed the bios says it has password
                  Post more ec file.
                    Post more ec file.
                    Heres one. Thank you
                      File corrupted
                        I'm sorry I forgot to upload his file
                          AAA
                            AAA
                            Thank you so much. It works!
                              I need to clean my password
                              hp elitbook 830 g8
                              sn: 5cg2073c9n
                              prodid : 26d48av
                                I'm still learning quite a bit from this group, so thank you! I was able to remove the bios password from the EC chip. I didn't touch the main. I'm getting hit with Endpoint security error. Any help would be appreciated.
                                HP Elitebook 840 G8
                                SN: 5CG2343RP6
                                PRODID: 6A3P3AV
                                  HP Elitebook 840 G8
                                  SN: 5CG2343RP6
                                  PRODID: 6A3P3AV
                                  do not touch the EC, flash the original untouched EC. and this main.
                                  first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                                  use BCU
                                  here's your DMI:
                                  Serial Number: 5CG2343RP6
                                  Product #/SKU: 6A3P3AV
                                  CT Number: PQSNP00WBH10R4
                                  Description: HP EliteBook 840 G8 Notebook
                                  BuildID: 21WWCVET601#SABA#DABA
                                  Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdpdqfAfPgSguhKjhk8mEmwn7nVngpq.3B
                                  MAC Address : C4:75:AB:CF:C7:4F
                                    After updating the bios it didn't turn on, only the side light kept flashing. I went to check the main dump behind the board and it was corrupted in the reading. Is it possible to generate the main and secondary bios? Donated!
                                    HP EliteBook 840 G8
                                    SN: BRJ146RKMZ
                                    CT: BKFNA035WF638B
                                    IEC P/N : 6037B0161911
                                    MAINBOARD: CORVETE - 6050A3217501 - MB - A01 (A1) (1086) L2
                                      HP EliteBook 840 G8
                                      SN: BRJ146RKMZ
                                      CT: BKFNA035WF638B
                                        Hp elitebook 840 g8 password locked please assist in unlocking this bios.
                                        prodduct id- 3V844UP#ABA
                                        S/N- 5CG1353XPG
                                        BOARD NO- CORVETTE- 6050A3217501-MB-A01 (A1) (1086) L2
                                        Attached is the main and Ec
                                        please help
                                          S/N- 5CG1353XPG
                                          please help
                                          here you only said bios password. this won't remove device freeze/ absolute lock.
