Working Bios Dump Fujitsu E554
  • Conste
    • Oct 2018
    • 235
    Just wanted to share a working bios dump for Fujitsu E554 Notebook
    The ones I found here will take long for the machine to boot and Num Lock will blink 5 times before POST.
    With the attached one there is no such issue, everything works perfect.
  • mohammed mohan
    • Nov 2017
    • 201
    • z
    Re: Working Bios Dump Fujitsu E554
    thanx
    Mohammed Mohan
    • O.Szilard
      • May 2019
      • 163
      • hungary
      thanx
      • yotoprules
        Fujitsu Amilo Pro V2030D BIOS DUMP
        by yotoprules
        I am looking for Fujitsu Amilo Pro V2030D BIOS DUMP.
        I downloaded latest BIOS from Fujitsu (for V2030) and flashed it as per instructions. After doing so the laptop has become unstable, I'm getting lots of BSODs, CRC errors, etc, and I didn't make a backup.
        I am unsure what difference, if any is between the V2030 and V2030D, but mine is the V2030D.
        The BIOS I flashed was 1.0H.
        Thank you
        09-29-2025, 11:43 PM
      • tofuSCHNITZEL
        Fujitsu Lifebook E547 vPro
        by tofuSCHNITZEL
        I have a Fujitsu Lifebook E547 vPro that does not boot anymore after Windows Update tried to install a new Bios version. Screen stays black no post - only the numblock light blinks.
        What I've tried:
        I have used my CH341A to read the bios chip (25Q128FVSQ) (Dump attached) - I think the dump is "good" because I could find the Serial number in the data and also the Winkeyfinder found a windows key.
        for the lack of any other Idea I took the bios from this post (https://www.badcaps.net/forum/troubl.../troubleshooti...
        10-15-2025, 04:26 PM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • EGUG
        Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
        by EGUG
        I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
        Serial number EICK023345
        Mainboard D3823-A2
        Hope somebody can help me.
        04-10-2025, 02:05 AM
