RCUnlocker
    Re: RCUnlocker
    Originally posted by il60 View Post
    Sorry really sorry
    thans for information for next time...
    Sn : C5CD051GMV8 yes, 650 g8
    yes i have password
    So now wait here if someone can help me ? or go ask on 650 G8 topic ?
    again, thanks for you"r help !
    Upload the image here, showing the password prompt screen.
    Become a Badcaps supporter
    Thanks to all supporters.​
      Re: RCUnlocker
      Could you please unlock this BIOS please ?
      Just did a donation because you are all very helpful
        Re: RCUnlocker
        Thank you very much for your support! Appreciate it!
        Here you are:
          Re: RCUnlocker
          Let me start out praising @RhetoricalCheese for an awesome application. Thank you sir!!
          This is my first chip (ever) that I am reprogramming so please be patient. I pulled a Winbond 25Q256JVEN (2202) (6141) (GM400) chip out of an HP Elitebook 850 G8 hoping to wipe the Admin password from the bios. I am using a XGecu T48 [TL866-3G] programmer. The chip did not work with any of the connectors I had so I had to use the test clip that came with it. I was able to READ then VERIFY the chip. I can see ASCII info that was added. I then saved the bios .BIN file and moved it to the RCunlocker.exe. But...I keep getting the same error, "Wrong Chip. Try reading and unlocking 16 MB chip." I am not sure what to do to get around this. I have tried using both "W25Q256JV SOIC8 and W25Q256JV SOIC16" but with no luck. I appreciate any help or input you can give me.
            Re: RCUnlocker
            Shouldn't be a problem but If you want the members here to help you, post your original backup (both dumps) and someone will do it for you.
              Re: RCUnlocker
              That is awesome!! Appreciate any help
              I am including the original BIOS from an HP Elitebook 850 G8 - Could you please unlock this BIOS?
                Re: RCUnlocker
                Sure, but you uploaded only the main bios dump - I've said both, where is the dump from the second (EC) chip?
                  Re: RCUnlocker
                  Sorry I was not aware there was a second (EC) chip that needed to be reprogrammed. Would you happen to know where this would be located? Maybe at the bottom of the board?
                    Re: RCUnlocker
                    Yes, it's at the back side of the board (U366).
                      Re: RCUnlocker
                      Thanks so much!!
                      Here are both the Main and EC bios files. I was able to extract the .BIN from the EC, but I thought it was weird that the software gave me a "Check ID" error. It told me to uncheck it and I then would be able to read/save the chip. When I scrolled through the ASCII section, I didnt see any characters like I did for the main chip read. The EC file is 32 MB.
                        Re: RCUnlocker
                        Thanks so much!!
                        EC dump is completely empty (FF filled), so you should try to read the chip again, use verification. What programmer you are using, ch341a?
                          Re: RCUnlocker
                          I have tried it again and verified.
                            Re: RCUnlocker
                            Well done. Much better attempt.
                            Below is your unlocked dump, program EC chip only (don't forget to erase it before programming), leave the other chip as is.
                            At the first boot enter the bios and reset security settings to default.
                            Then enjoy your unlocked toy, and don't forget to buy me a beer, you can do that by
                            making a donation in support of the "Bios Requests" section of the forum.
                            P.S. Just in case before all that take one more verified dump of the EC bios chip. Just to be on a safe side. I've checked your second read and it's looking perfectly fine, but as I said just in case, and for the sake of following the right procedure.
                            Leave feedback and Good Luck!
                              Re: RCUnlocker
                              Appreciate the help. But....I am getting this error when I program the EC. Help please!
                                Re: RCUnlocker
                                I don't know exactly what the problem is, most likely bad contact between the programmer and the chip. What is the connection type - wson8 to dip8 adapter or something else?
                                  Re: RCUnlocker
                                  I was able to program the original .BIN file back to the EC with no issues. I am using a tester clip socket.
                                    Re: RCUnlocker
                                    So what's the problem then, program the unlocked file the same way.
                                    This "tester clip" as you call it is not intended for use with WSON8 SPI flash chip hence the problem. This clip is designed to be used with SOIC-8 SPI chip.
                                    So as I already supposed - your problem is a bad connection with the chip.
                                      Re: RCUnlocker
                                      Sorry for late answer, you was right, i post the wrong bios laptop bios
                                      thanks for all !
                                        Re: RCUnlocker
                                        So I have a hp EliteBook 8470p with a Winbond 25Q128fvsq chip. I pulled the bin file from chip with exp2019+ and then I verified it. Everything appeared to be ok. So as I go to read it again every attempt to read chip shows chip is empty? What should I do from here? Any suggestion would be helpful. Also I've attached the original read I pulled. Thanks !
                                          Re: RCUnlocker
                                          yes, you wanted to delete his password, look at the bios here..
