asus vivobook TP412F
  • omar mokhtar
    • Nov 2016
    • 38
    • egypt
    please help
    i need bios
    MotherBoard Model
    TP412FAC
    Laptop Model
    TP412F
    Last edited by SMDFlea; 08-08-2021, 03:07 PM. Reason: Added "TP412F" to thread title
    • 20781
    Re: asus vivobook TP412F
    Post your bios backup and a good clear picture of the white sticker on the motherboard,the one with the QR code on it.
    • omar mokhtar
      • Nov 2016
      • 38
      • egypt
      this dump and model with qr
      • omar mokhtar
        • Nov 2016
        • 38
        • egypt
        any help please
          • 20781
          • omar mokhtar
            • Nov 2016
            • 38
            • egypt
            this
              • 20781
              The bios you posted is from an X403FA.
              Try this one.
              690020 FFE0
              • omar mokhtar
                • Nov 2016
                • 38
                • egypt
                not work
                  • 20781
                  Originally posted by omar mokhtar
                  not work
                  ok try this one.If it doesn`t work this time i`m sure your problem is somewhere else .
                  • rielfreak
                    • Jul 2017
                    • 23
                    • Philippines
                    Asus TP412FAC R2.0
                    Hello guys. Can someone clean this BIOS for me please. Unit has no display. Thanks in advance.
                      • 20781
                      Re: Asus TP412FAC R2.0
                      Post a good clear picture of the white sticker on the motherboard,the one with the QR code on it ,like the one at post #6
                      • rielfreak
                        • Jul 2017
                        • 23
                        • Philippines
                        it's the same board with post #6. sorry i can't upload the picture. I'll try the clean ME you uploaded.
                        • rielfreak
                          • Jul 2017
                          • 23
                          • Philippines
                          It turns out that the problem was the load switch. I cant identify the original part but i replaced it with TPS22961from a donor board. Unit turns on with battery power only. Can't turn on with AC adapter plugged in. It draws 0.04A in my bench PSU.
                          • Verlengsnoer
                            • Sep 2016
                            • 109
                            • Netherlands
                            does someone has a bios for this one?
                            dont have the laptop at home, so i cant deliver a backup,
                            the problem with the laptop is its totally dead, no lights, no power
                            • Mazorca
                              • Jan 2017
                              • 463
                              If it is totally dead it has a hardware problem, hook it up to a bench power supply and look at miliamps consumed. Power button not pressed should be around 25-35 mA, once pressed, if no battery, from 600mA to 1.5A, depending on laptop. Gaming laptops draw a lot. Check for the 5V and 3.3V voltage rails, particularly at leg 8 of BIOS chip, 3.3V or 1.8V for new ones.
                              • swanand
                                • Dec 2011
                                • 50
                                here is your bios display tested in screen 100 % working
                                • abitboulette
                                  • Nov 2022
                                  • Belgium
                                  hello all.
                                  @Swanand may I use yours on mine, please?
                                  L623NBLP00037LMB
                                  TP412FAC
                                  60NB0N30-MB5110
                                  200
                                  • peste
                                    • Dec 2016
                                    • 12727
                                    • ROMANIA
                                    Originally posted by abitboulette
                                    hello all.
                                    L623NBLP00037LMB
                                    TP412FAC
                                    60NB0N30-MB5110
                                    200
                                    post the original bios of the laptop here..
                                    • abitboulette
                                      • Nov 2022
                                      • Belgium
                                      Hello @Peste,
                                      Sure, please find in attachment the dump of the winbond.
                                      In the meanwhile, I have tested the ME_modded which was not working.
                                      thank you
                                      • paimz87
                                        • Feb 2022
                                        • 13
                                        • indonesia
                                        Hello, can someone unlock this bios? please teach me how to do it
                                        Model: TP412FA-EC463T
                                        Main board model: TP412FAC R2.0
                                        S/N: L2N0LP00998609E
                                          ASUS VivoBook TP412FAC-EC373T Hybrid (2-in-1) Flip 14 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook TP412FAC-EC373T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TP412FAC-EC373T boardview and TP412FAC-EC373T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 02:20 AM
                                          ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-07-2024, 02:50 AM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          ASUS VivoBook VivoBook 14 Notebook 14 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook VivoBook 14 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VivoBook 14 boardview and VivoBook 14 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 04:10 AM
                                          ASUS VivoBook S531FL-BQ127T Notebook S15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook S531FL-BQ127T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S531FL-BQ127T boardview and S531FL-BQ127T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 10:56 AM
