need bios dump of dell latitude 5320
    Originally posted by Markus1741 View Post
    Try this unlocked file ....
    The device does not power on after writing the file
      need to unlock bios password reset
      i have attached my old bios file
      Dell Latitude 5320
      service tag - dxgyfg3
      express code - 30322034355
      mbd code - 19817-1 south peak 13 10 L WDJR$JA
        Dell Latitude 5320
        Unlocked
        Become a Badcaps supporter
        Thanks to all supporters.
          Check the bios chip solder joints again.
            Originally posted by hoaca388 View Post
            Unlocked
            its working thank u
              PLEASE BUILD THIS BIOS Latitude 5320
              ST. 93BD2B3
                i have a dell 5320 that hangs on the bios logo dell
                i kindly need your assistance with it.
                attached is the original backup
                sorry i don't have access to the service tag
                  try
                    Originally posted by qayyum786 View Post
                    try
                    Same problem.
                    machine hungs at the dell logo
                    i have detached all peripherals but still the same.
                      Originally posted by hirens View Post
                      Same problem.
                      try.. give feedback test that both clearme and the other.
                        thanks alot
                        the clear me worked perfect bro
                        thanks
                        • rex98
                          rex98 commented
                          Editing a comment
                          thanks also for feedback. now i know it works
                        Hi everyone. Can you please help.
                        Dell latitude 5320
                        Reg Model: P138G
                        Reg Type No: P138G001
                        Service Tag: GJJVFG3
                        EX: 36010753779
                        MFG YR:2021
                        Cannot access Absolute Menu (Absolute computrace menu) and Want to change Service Tag. I attached my back up. Thank You
                          Dell latitude 5320
                          Reg Model: P138G
                          EX: 36010753779
                          MFG YR:2021
                          https://www.badcaps.net/filedata/fetch?id=3172666
                          use the clearme.
                            Hi. rex98,
                            thanks for your reply.
                            tried the cler me.bin -not working.(can enter bios, but all options in bios are grayed/disabled) not booting the HDD.
                            tried the DELL LATITUDE 5320 19817-1 SOUTH 13 10L CLR ME REGION TESTED OK.bin - not powering on.
                              Dell latitude 5320
                              Reg Model: P138G
                              EX: 36010753779
                              MFG YR:2021
                              Cannot access Absolute Menu (Absolute computrace menu) and Want to edit Service Tag. I attached my back up. Thank You
                              Last edited by Vesko356; 02-01-2024, 04:44 PM. Reason: Attached bios removed, already posted above.
                                Dell latitude 5320
                                Reg Model: P138G
                                EX: 36010753779
                                MFG YR:2021
                                try.
                                  try.
                                  hi rex98,
                                  thanks for the file. I tried it, but the laptop is not powering on. I try to plug in charger, charger led indicator not lighting on. The LED indicator blink every time i press power on button.
                                  I tried the original bios, the unit is perfectly working, but the Absolute Menu is grayed out, cannot change setting.
                                  please help.
                                  thank you
                                    Dell latitude 5320
                                    Reg Model: P138G
                                    EX: 36010753779
                                    MFG YR:2021
                                    Send to you, try
                                      Pls help unlock admin password and disable absolute.
                                      ST:41FPTG3
                                      EX:8793994323
                                      thanks.
                                        ST:41FPTG3
                                        EX:8793994323
                                        thanks.
                                        try. 1st boot be patient wait until screen displays. then press F2, write service tag, disable Absolute, apply changes, restart. 2nd boot press alt+F to exit factory mode
