Persona Mybook 14i Dump Needed
  • dennison flores
    • Apr 2021
    • 22
    • Philippines
    hi to all.. i want to ask for a help again. i am repairing a laptop which is uncommon brand (PERSONA MyBook 14i). I need to reflash it's bios. can somene help me? attached here is the old dump... Thank you in advance...
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Persona Mybook 14i Dump Needed
    try..
    • dennison flores
      • Apr 2021
      • 22
      • Philippines
      Originally posted by peste
      try..
      thank you sir... i will this one. and give update after the flash
      • dennison flores
        • Apr 2021
        • 22
        • Philippines
        try..
        after flash same problem exist.. i found out that coil is heating up... thank you for your help sir...
        • dennison flores
          • Apr 2021
          • 22
          • Philippines
          Persona P419 Dump Needed
          hi to all.. i want to ask for a help again. i am repairing a laptop which is uncommon brand (PERSONA P419) it is my second time to deal with this kind of brand. the first one were not repaired by bios flashing because the problem is the coil. this one is no display. I need to reflash it's bios first. can somene help me? attached here is the old dump... Thank you in advance...
            • 22293
            Re: Persona P419 Dump Needed
            Is there any part numbers silkscreened on the motherboard
            • dennison flores
              • Apr 2021
              • 22
              • Philippines
              here it is sir SMDFLEA...
              • re-atari
                Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                by re-atari
                Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                02-03-2025, 06:49 PM
              • rednix01
                Nuc7i5BNH Bios Dump Needed
                by rednix01
                I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
                Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
                I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...
                06-19-2025, 06:37 PM
              • erkko13
                Thinkpad L390 Yoga (type 20NT serial R90VZWLN) BIOS2 dump needed
                by erkko13
                Ho ho ho, badcaps people,
                if this qualifies as bios request, hopefully. Actually BIOS2 for that laptop is second smaller SPI flash (Winbond W25Q80DVSNIG-GP-U), containing supposedly some config for TPS65988 which in turn manages USB-C stuff, including PD. This is possibly flash, where update "Power Delivery Firmware (TI TPS65988)" F407.06.29 -- https://download.lenovo.com/pccbbs/mobiles/r10pd10w.exe does its thing. Previous owner claims that after clean install of Windows 10 he installed thinkvantage tool of sort, which updated everything for that laptop. I did glance over...
                12-25-2024, 06:41 AM
              • jorpec
                Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
                by jorpec
                Hi, all
                I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
                10-17-2025, 03:51 AM
              • hirens
                Lenovo ideapad 3 14IGL05 bios dump needed
                by hirens
                model: 81wh
                sn: pf36ta6h
                board no: nm-c961 gs453/gs553
                hey guys above is my laptop info
                it only blinks the power button kindly help me with a working dump
                old dump attached...
                07-21-2023, 04:48 AM
