IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Originally posted by rusovich View Post
    the laptop show invalid this is the problem, the file is original backup of machine
    ok i cant add this dmi sorry tanks
      Hello
      after bios update from lenovo support software.. my laptop only shows black screen
      v14 ada
      82c6 ryzen3
      sn : PF361DHV MTM : 82C600DJAX
      help please
        Originally posted by ahmedsaeid2k View Post
        Hello
        v14 ada
        82c6 ryzen3
        help please
        Add your bios dump even if it is corrupted.
        Become a Badcaps supporter
        Thanks to all supporters.​
          Hi there. Such a problem
          After updating my laptop ... The WI-FI adapter disappeared everywhere and the keyboard does not work at all in Windows itself. Everything works in the bios itself. Changed the update from the site, it did not help.
          Product Name: Lenovo V15-ADA
          Bios Version : E8CN36WW
          EC Version : E8EC36WW
          MTM: 82C70065CK
          Please help me
            MTM: 82C70065CK
            Please help me
            read post #23...
              can you drop the link?
              I'm new here on the forum
                Each post has a number, yours is #86 - it can be seen in the right upper corner, the post Peste pointed to you has a smaller number, so it's obviously back into the thread, and if there is no link to it, you will have to find it yourself, in this case it is at the beginning of the second page.
                  Please i need bios bin for...
                  V14-ADA Laptop (Lenovo)
                  Type 82C6.
                  SN: PF2QKTD7
                    Type 82C6.
                    SN: PF2QKTD7
                    What's the issue with your laptop?
                    Add your factory dump.
                      hi can some one add my serial number to the bios please.
                      IDEAPAD 3 15-ADA
                      MODEL: 82C7
                      SN:PF20RF7X MTM:82C70005UK
                        IDEAPAD 3 15-ADA
                        MODEL: 82C7
                        If you have a good bios backup you can add the DMI to the new bios yourself
                        https://www.badcaps.net/forum/showpo...8&postcount=66
                        https://www.badcaps.net/forum/showthread.php?t=96800
                          Thanks though i am just leaning about bios flashing, and seems a litle complicated, i dont have the old original bios only my serial numbers and a copy of a virgin bios from here that has another persons dmi on it
                            Didn`t you make a backup before flashing the new bios ? .The DMI area is encrypted ,so it can`t be edited with a hex editor. There are some lenovo DMI tools that you can try, i don`t know which one will work
                            4.7. Lenovo https://www.badcaps.net/forum/showpo...43&postcount=5
                              ok thank you for the help i will persist somehow and try an solve it myself
                              the old bios would not read i think the chip was faulty and i kept getting read errors this was the problem , i took a different chip same size and tried a few bios files from this thread but black sreen , fan spin only caps lock not work
                                Re: Lenovo V15-ADA NM-D151 BIOS please
                                Originally posted by digix View Post
                                Dump from Lenovo V15-ADA , mainboard GV451&GV551 NM-D151 Rev:1.0 and BIOS exctracted from BIOS update.
                                thank you working
                                  https://download.lenovo.com/consumer...s/e8cn27ww.exe
                                  Guide: How to extract and edit a Lenovo Phoenix TDK Bios - https://www.badcaps.net/forum/showthread.php?t=80861
                                  Add your own DMI from your backup using software and the attached CopyDMI script. Follow the Easy Guide
                                  Guide: Copy DMI info easily with Hex editing software and Macro script - https://www.badcaps.net/forum/showthread.php?p=1214739
                                  Followed your instructions and saved Lenovo Ryzen 5 laptop from bad BIOS!
                                  Thank you!
                                    Hello
                                    After I installed a new bios update my laptop was turning on but it was only the black screen
                                    I tried everything from above but nothing works
                                    I have the read ''dead'' file attached
                                    Could someone please help me with this?
                                    Lenovo V15-ADA
                                    SN:PF239EYS
                                    MTM:82C70061RM
                                      Originally posted by vasiacp View Post
                                      Hello
                                      Lenovo V15-ADA
                                      SN:PF239EYS
                                      MTM:82C70061RM
                                      Try and give Feedback
                                        Still nothing
                                          Still nothing
                                          you have everything you need for post#1, if it doesn't work it means you are writing the bios with errors...what programmer do you have??
