HP EliteBook x360 1020 G2 6050A2895901-mb-a01 BIOS
  • mirai
    • Mar 2021
    • 20
    • Danmark
    Hi Guys, I hope you can help me out with these two dumps. There's a BIOS psw. Thanks in advance!
    MX25L6473FZN and W25Q128JVPQ
  • peste
    • Dec 2016
    • 12944
    • ROMANIA
    Re: HP EliteBook x360 1020 G2 6050A2895901-mb-a01 BIOS
    try..
    • mirai
      • Mar 2021
      • 20
      • Danmark
      Hi peste,
      Thank you for the cleaned version. As I understand, 8 MB dump should stay the same?
      I tried to write the cleaned 16 MB dump, but the notebook could not start. Flashing yellow/white charge light, tries to start, fan speed increases until max and it restarts to the same.
      I flashed the backup back of 16 MB chip, but result is the same - fans high, yellow/white led flashing. I wonder what is the problem?
      • mirai
        • Mar 2021
        • 20
        • Danmark
        Originally posted by peste
        try..
        Hi Guys,
        Could anyone give another try at cleaning the dumps? Thank you in advance.
        Br,
        mirai
        • mirai
          • Mar 2021
          • 20
          • Danmark
          HP EliteBook x360 1020 G2 BIOS password removal
          Hi all! I hope you can help me out with these two dumps. There's a BIOS password I need to remove. Thanks in advance!
          MX25L6473FZN and W25Q128JVPQ, 6050A2895901-mb-a01 motherboard.
          Pete has previously provided me a Orig+P90_0138.rar but it does not work, led is flashing, fans spinning, black screen.
          If you have info what needs to be cleaned and how, please share so I can try fixing myself, thanks.
          • mirai
            • Mar 2021
            • 20
            • Danmark
            Is there a reason you guys do not reply for me? I am really stuck here.. Should I donate or something? Please help.
              • 21145
              No, this site is for free help,nothing needed , only a bit of patience.
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                "Well, it's standard UEFI definition..."
                Slava Uhani
                Become a Badcaps supporter
                Thanks to all supporters.
                • mirai
                  • Mar 2021
                  • 20
                  • Danmark
                  Hi Vesko356, thanks for a attempt. I do get the same result no matter it is your cleaned dump, the one I made with RCUnlocker, or the one I bought from someone:
                  In sequence:
                  Orange/white LED flashes for a few seconds, 7-10 times;
                  All off;
                  White power LED powers on, orange is on, fans try to kick in but stop;
                  White LED off, orange stays lit, fans kick in and go to 100%, nothing else happens.
                  I am starting to think something wrong is with motherboard, even though it was functioning fine before the reading/flashing the EC and BIOS. Sometimes if I read both flash chips, I can see that contents are modified by PC. I assume SecureBoot is trying to recover BIOS/EC original content..
                  Does anyone else have any idea how to go forward?
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    In sequence:
                    All off;
                    Does it boot with the original (locked) bios?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11878
                      In sequence:
                      All off;
                      You try using RC Unlocker then clear ME the unlocked file
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        If the factory bios is dumped correctly (verified) from the chip, there is no need to clean (additionally) the ME firmware, if the problem is only the password.
                        • mirai
                          • Mar 2021
                          • 20
                          • Danmark
                          Is there a way to check whether the dump was made correctly? I have done 5 readings of each, all were verified, all are bit-identical. I do program with Rasp Pi, chose low speed, etc.
                          I know it is a dumb question, perhaps there is a straight forward answer to that.
                          • mirai
                            • Mar 2021
                            • 20
                            • Danmark
                            Just checked it. No, same behavior. I assume it's either the dumps were incorrect or HW damage. Would you know if I can do some merging of the locked dump with a clean one to produce something that might work? I think peste did somethin similar.
                            I am not sure if there is anything wrong with HW. The EC and BIOS ICs are working, I checked the pull up/downs around, seems fine.
                            I actually read all the threads with EliteBooks 10x0 requested to be unlocked. A few similar cases of fan spinning, LEDs flashing but everyone seemed to be able to at least roll back to original locked state.
                            • mirai
                              • Mar 2021
                              • 20
                              • Danmark
                              I would hate to throw away such a nice laptop..
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                This is usually enough to make sure the chip is read correctly. Even two or three readings of the chip that are identical to each other mean that the chip is read correctly. Unless, of course they are all FF
                                BTW you didn't answered my question - Does it boot with the original (locked) bios?
                                • mirai
                                  • Mar 2021
                                  • 20
                                  • Danmark
                                  I know! I was so sure at the time that they are fine and now I am in doubt. Anyways, the RCunlocker shows the info, except MAC address being zeros. Thus, I assume something is read for sure.
                                  To answer your question, I just checked it, no it does not boot. Same behavior.
                                    • 21145
                                    Did you flash both the originals back, in the same places, you havn`t mixed them up ?
                                    • mirai
                                      • Mar 2021
                                      • 20
                                      • Danmark
                                      First I read "soldered" in the same places, but then it made me think, could I have mixed them up.. Probably not, but I will double check that.
                                      Also, due to many flashing attempts, I have the ICs unsoldered and in the adapters, connected to either Rasp Pi or the motherboard through 8 pin connector. I wonder if the relatively long cables have any influence on communication with motherboard, I assume it runs 200-400 MHz depending on dual/quad mode while RPi has max 16MHz (?).
                                      Should I try to construct the new image by merging old dump with a new BIOS? Any other ideas?
                                      • mirai
                                        • Mar 2021
                                        • 20
                                        • Danmark
                                        Hi SMDFlea, do you recall what did you do or what was the problem with this particular case? The blank screen and white/yellow flashing sounds familiar and the guy eventually had it solved.
                                          HP EliteBook x360 EliteBook x360 1020 G2 Notebook Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1020 G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1020 G2 boardview and EliteBook x360 1020 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 06:10 AM
                                          HP EliteBook x360 1020 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 1020 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1020 G2 boardview and 1020 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 06:40 AM
