Lenovo Thinkpad T480 BIOS and EEPROM request
  • Luis Martin
    replied
    Originally posted by SMDFlea
    Extract the attached zip folder, make a USB recovery drive with mkusbkey.bat ,boot from the USB drive and it will or should update the bios and EC.
    Thanks!, it works. IDK what the EC (Embedded Control) was, but I do a quick search on Chat-GPT explained very good even teach me how to modify hex data using hex editor programs.
ID:	3655880 Click image for larger version
    replied
    Originally posted by Luis Martin
    this bios
  • Luis Martin
    replied
    To be honest idk, i just get a update firmware pop-up and click on it.
    I find this .bin on another forum and I flash it, and it works now i got Lenovo screen and i can go to bios but .... now if i plug a hdd/ssd the system just start blinking the screen in black.
    If I remove ssd the system boot from my usb to install operating system but I can't because no ssd installed​. đŸ¤”
    this bios
  • Luis Martin
    replied
    Did you get the update from LVFS https://fwupd.org/ ,was the EC updated as well.
    replied
    Thank you SMDFlea.
    Unfortunately doesn't work.
  • Luis Martin
    replied
    try this one.
    Thank you SMDFlea.
    replied
    Lenovo T480 bricked during a firmware update on ubuntu system, light on power button and fan turn on, no screen or HDMI output. Bip bip sound when turn on without RAM.
    Brand: Lenovo T480
    board No: Et480 nm-b501 (2018)
    s/n: Pf-1EQ53J 18/09
    Type: 20L5-000WUS
    processor type: i5
    issue: bricked during a firmware update
    requesting: working BIOS.
    The 3 attached files are the same DUMP with 3 different chips names for redundancy.
    try this one.
  • Luis Martin
    replied
    Brand: Lenovo T480
    Type: 20L5-000WUS
    processor type: i5
  • OrcunerenGungen
    replied
    I fixed the issue it was the d12 diode on the back I put a wire for now I hope it helps someone else Also you can put a wire instead of 33 ohm resistors no problem but putting a new diode is recommended
    replied
    Originally posted by OrcunerenGungen
    I couldnt edit my post The 3.3v comes to CS after plugging adapter doesnt come with battery
    Replace the caps and resistors then it might just work properly.
  • OrcunerenGungen
    replied
  • OrcunerenGungen
    replied
    SN:PF1AQ6LW Model:20L6S0AF00 cant find mobo model
    replied
    Hello I have a t480 with supervisor password. I dumped the bios and patched it with the patcher on this forum. I got verification errors at first but after using another software to write with ch341a I was able to write and verify. But laptops power button blinks 3 times and nothing happens even with original bios. Can anyone take a look at my dump? I also tried other dumps from sit e but same thing. Also I noticed a resistor and 2 caps missing I bridged the resistor and left the caps as is Any Help is Much Appreciated. The resistor is r694 and it is 33 ohm and 2 missing 33p caps c576 and c577 There is 1.6v at vcc of bios and 3.3v at cs
    Type the laptop serial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
  • OrcunerenGungen
    replied
  • ali0robot
    replied
    Originally posted by eKuliscool
    Hello guys I really need your support because i tried to modify my bios and flashed it and after that nothing worked anymore...
    My Thinkpad T480 doesnt turn on anymore and there are no lights, fan spinning etc... - so basically dead. The only thing working is when i plug it via AC then it charges.
    I flashed the bios Chip with a lot of other verions provided in this post and nothing helped unfortunalty.
    My Setup is the following:
    Type: 20L6-S29E0C
    S/N: PP-1QC3TB
    Mainboard: i can"t tell you the exact Mainboard because i couldnt find any information about it on itself but i guess its ET480 NM-B501 as usual because i havent seen any other serial number for it.
    I would really appreciate the help because i really despair at this task.
    So if someone could help me and also need some more information i would love to provide them.
    (If its possible to give me an bios with a patched version (advanced menu, overclocking and erasing wwan whitelist) it would be even more perfect but not needed )
    I have no back up bios - because mine was broke and the only thing that matter is that my T480 will work again.
    Best regards and Thanks
    if you have 3.3 on bios chip look for resistance around bios chip, sometime one of those resistance are misplace or lost. in most cases they are 33 or 50 ohm
  • ali0robot
    replied
    Originally posted by anirash25
    Please help Clear the Bios Password Lenovo T480
    MB Part No: NM-B501
    Laptop Serial No : PF-1K59S7
    try
    commented on 's reply
    Try the Autopatcher - https://www.badcaps.net/forum/troubl...emoval?t=87588
  • anirash25
    replied
    MB Part No: NM-B501
  • eKuliscool
    replied
    Type: 20L6-S29E0C
    S/N: PP-1QC3TB
  • khrapr
    replied
    Please need help to remove supervisor password, I've been tried run Lenovo auto patcher and its doesn't work, after power on my laptop "sings" or melody after few second and no picture.
    Type T480 20L5-20L6
    S/N PF1GR4NL
    Bios Version : N24ET79W 1.54
    Thank's for your help.​
    Lenovo ThinkPad T480 Notebook T Specification for Upgrade or Repair
    This specification for the Lenovo ThinkPad T480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T480 boardview and T480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
    09-06-2024, 03:21 PM
    09-06-2024, 02:34 PM
    09-06-2024, 02:28 PM
    09-06-2024, 12:30 PM
    09-06-2024, 11:39 AM
