Lenovo Ideapad S510p need bios dump
  • lashakaraulashvili
    • Dec 2020
    • 13
    • georgia
    Hello, need bios dump this version not other ones.
    version: 89CN32WW
  • mximiliandz
    help bios lenovo ideapad s145-14iil type 81w6
    by mximiliandz
    Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
    06-20-2025, 06:50 AM
  • jendkkd jeje
    Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
    by jendkkd jeje
    So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
    I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
    10-11-2024, 03:12 PM
  • AHmad_Salal
    Need BIOS Dump/ROM for Lenovo Thinkstation p500
    by AHmad_Salal
    Hello all,
    I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
    11-28-2023, 05:28 AM
  • hirens
    Lenovo ideapad 3 14IGL05 bios dump needed
    by hirens
    model: 81wh
    sn: pf36ta6h
    board no: nm-c961 gs453/gs553
    hey guys above is my laptop info
    it only blinks the power button kindly help me with a working dump
    old dump attached...
    07-21-2023, 04:48 AM
  • lngcs
    Bios dump need for lenovo ideapad 1 15ALC7
    by lngcs
    Hi, could some one please help extract or provide bios dump for Lenovo ideapad1 15alc7, MTM:8244007aau,s/n:pf4k2bzn.thanks...
    09-24-2024, 11:11 PM
