X250 with bios lock
    Re: need to pach this file lenovo x250
    Hi freind
    I cant modify any thing in setup becaus is disabled
    I read the bios with rt809h i write it but alwas ask me for password when i press enter in keyb i access to setup but we cant change any value
      Re: Help to patch bios lenovo x250
      Originally posted by Mazorca View Post
      Try it now, instructions inside. Follow them closely. I've done several x250's and all worked. Remember to put the backplate or bottom after writing the patch, no batteries. I think there is a small switch that needs to be pressed, putting the backplate will solve that.
      Pleas freind can you help me to solve my labtop
        Solved many thank's
          Help to patch lenovo x250
          Hi help to disable password for 2 labtop
          X250
          I patch some bios with lenovo patcher an python 3.7
          But i"m not lucky to patch this 2 pc
          Pleas any one can patch it for me
          Thanks freind
            solved for me also need close back cover tnx
            Originally posted by douha View Post
            Solved many thank's
              Levovo x250 viux1 nm-a091 rev:1.0 unlock password
              Hello
              need help to unlock my x250 bin pls
                Re: Levovo x250 viux1 nm-a091 rev:1.0 unlock password
                Originally posted by jougounou View Post
                Hello
                There is no need to make a new thread when there are other X250 threads where you can post your request.
                Havn`t you tried the lenovo Autopatcher,or checked for a prepatched bios ?
                https://www.badcaps.net/forum/showpo...42&postcount=4
                You MUST:
                Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
                  Need help to unlock TP X250 Bios
                  Hello everybody,
                  i got a used a Thinkpad X250 and dont have the Bios pw. Attached is the Bios dump. Does anybody have a tip? Thank you in advance
                  Felix
                    Re: Need help to unlock TP X250 Bios
                    Originally posted by Ballou View Post
                    Hello everybody,
                    Felix
                    Hello read this ...
                    https://www.badcaps.net/forum/showpo...52&postcount=1
                    and her is your patched file ...
                    Good luck
                      Re: X250 with bios lock
                      Hello Markus,
                      thanks a lot! Awesome.
                      Greetings to Bavaria ;-)
                        I am newbie, i just bought x250 to my surprise it is bios lock how to remove the password, can i used the patched bios here posted and how to flash,
                        Please help thanks
                          Please help thanks
                          https://www.badcaps.net/forum/showthread.php?t=103526
                            Good morning, please help me, I'm a beginner. Lenovo x250 with bios password. I read the original bios using ch341a, used the autopatcher and everything was fine. I uploaded it, after turning it on I have 2 x 5 signals and after 2 minutes the board turns off. what am I doing wrong?
                              Vesko356 commented
                              Editing a comment
                              Thread merged.
                              Read the rules before posting!
                              You MUST:
                              • Post under a related thread if it exists
                              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                            #54
                            lenovo ThinkPad x250,
                            type 20CL-S5T900
                            s/n 09G0MG 15/12
                            VIUX1 NM-A091
                            REV 1.0
                            17.04.2013
                              Vesko356 commented
                              Editing a comment
                              Originally posted by Mrówa112277 View Post
                              prosba o wsparcie
                              Post in English only please!
                            #55
                            i have password on lenovo x250 need patch thanks
                              Vesko356 commented
                              Editing a comment
                              You MUST:
