Dell Latitude 3400 bios password -E7A8
    Good afternoon, please help me with the password
    71NDHC2-E7A8
    SERVICE TAG(S/N): 6FY23H2
      71NDHC2-E7A8
      Read the post above, try to unlock it yourself. You will need a US qwerty USB keyboard
        I tried it, it didn't work, I spent two days
          Ok, post your backups.
              HELP: Dell Latitude 3490 bios password -E7A8
              Good night! Could someone help me with the "master password" Do the DELL Latitude 3490 Service TAG 3N6SFV2-E7A8
              TANKS
                TANKS
                3.4. Dell
                Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                Note: There is no publicly available 8FC8 generator available at the moment.
                The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                Become a Badcaps supporter
                Thanks to all supporters.
