hp elitebook 850 g5 bios password
    Re: hp elitebook 850 g5 bios password
    Originally posted by alltalk View Post
    the unlocked file youve sent is the same as I generated with rcunlocker.
    what would change by flashing the main too?
    thanks for your help - appreciate it
    flash the main coz the main is patched its clean. give feedback
      Will do tomorrow when I'm back at work
        all good
        password gone
        can't thank you enough
        much appreciated
          Need to flash 2 chips, or only the main one?
            tnx . working
              Hello guys
              i need unlock this dump
              remove password
              thank you
              or another new dump bios
              Hi
              I have an HP Elitebook 850 G5 with a PW protected bios. I have tried a few of the unlocker tools but with no sucess. Could someone tell me the Bios PW or remove all the PW's from the attached bios please?
              HP Elitebook 850 g5
              SN# 5CG8496G4N
                Originally posted by Crizby View Post
                Hi
                HP Elitebook 850 g5
                SN# 5CG8496G4N
                After entering BIOS, go to security tab and reset security settings to default!
                Security errors are expected once or twice on first boots.
                Try and reply with results.
                  Thank you. You are a star. That has removed the PW.
                  I reset the security settings to default but I now get an "HP Endpoint Security Controller Problem" on every boot. Its not a major issue as the laptop still boots up.
                  Is there an easy way to fix this?
                    hi . I need delete the password bios of a hp elitebook 850 g5 .
                    thanks.
                    thanks.
                    hi pls send serial number and send 16mb bios chip
                      ProdID 3JX19EA#ABC
                      SN# 5CG823548J
                      Mainboard COMPUTRO-6050A2945601-MB-A01( A1 )
                        ProdID 3JX19EA#ABC
                        SN# 5CG823548J
                        only flash this EC.
                          Originally posted by rex98 View Post
                          only flash this EC.
                          Everything works! Thanks for the help!
