Dell Latitude 3490 Bios Help
    Re: Dell Latitude 3490 Bios Help
    Originally posted by peste View Post
    try..
    Thank you very much.
    100% Working
      thx
        Latitude 3490
        Service Tag: GPX81W2
        Don't try to search for bios problem anymore if this file doesn't work.
        Thank you
        Working 100% 😘😘
          Hi, can some one help me unloking this bios
          Latitude 3490
          P89G
          P89G001
          Service Tag: F03G8T2-E7A8
            Latitude 3490
            P89G
            P89G001
            https://bios-pw.org/
            Become a Badcaps supporter
            Thanks to all supporters.
              I tried both of the codes, but they don't work.
              spa lat keyboard
                try..
                WORKED THANKS.
                  I have a couple of this model laptop that I've tried removing MDM from in our shop standard method here, but these devices are still re-affiliating with Entra. I've attached the original BIOS as well as my attempt at removing if someone could help me out. I can't just do the thing offline because these devices are for further downstream users.
                  Latitude 3490
                  ST: BKWSKP2
                  Board Model: LA-F115P Rev: 1
                    Latitude 3490
                    ST: BKWSKP2
                    Latitude 3490
                    Service Tag: BKWSKP2
                      Latitude 3490
                      Thanks for your effort however, the device is still re-affiliating with Entra. And this is with a totally random clean Hard disk. I must be missing something fundamental here.
                        Have you reset the settings to default ?
                          Hello, yes, I started by reflashing the file you sent me, "clearing Keys" in TPM security settings menu, and disabling absolute. I wiped the drive, and tried to reload windows, and same thing. So I flashed the file you sent me again and and tried restoring all settings in BIOS to factory default, and same thing. Still hitting Entra.
                          Maybe I should load it offline and use the powershell command to see if it's still pulling a key from UEFI?
                            Was it successful??
                              Originally posted by Vesko356 View Post
                              Re: La-f116p
                              Both are wrong...
                              And next time release the Caps Lock.
                              Service Tag: DHH7BV2
                              Express Service Code: 29354990798
                              Hi, can you remove password for me please?
                              DELL Latitude 3490 LA-F116P
                              ST:84J04W2
                              Thanks!!
                                ST:84J04W2
                                Thanks!!
                                ST:84J04W2-Suffix ?
                                  Originally posted by danito View Post
                                  ST:84J04W2-Suffix ?
                                  84J04W2-E7A8
                                    84J04W2-E7A8
                                    Try and unlock it yourself, you will need a US qwerty keyboard https://www.badcaps.net/forum/troubl...23#post1622423
                                      OMG it works!!
                                      Thank You!!
                                        Hey sir
                                        This is my old bios of Dell 3490 machine
                                        It's problem is that it remains stuck on "Dell logo" for 2 to 3 minutes and boot up is dead slow
                                        But when it boots to windows it works perfectly
                                        Unfortunately machine service tag and express code is missing
                                        Plz help me
                                          no power plz clean the bios sir
