    Originally posted by straki007 View Post
    Hi guys.
    I'm struggling here with my Thinkpad X250.
    Can't start after last night (apparently updates).
    My BIOS is locked and I don't know how to proceed with autopath.
    PORAD shows me that it saves the file, but it doesn't save it anywhere.
    Can you please help me unlock my BIOS?
    Thank you.
    Try this file ... build whith AUTO-PATCHER ...
    And read this ...
    https://www.badcaps.net/forum/showpo...52&postcount=1
      Big thanks.
      But notebbok it beeps 5 times twice in a row and the screen is black.
        Big thanks.
        Hello Try this: Are all batteries removed Battery + CMOS
        If so, press the power button for more than 10 seconds.
        Reset NVRAM
        How would the BIOS be read out via clip or chip desoldered.
        A picture of the current chip would be helpful.
        Check if all capacitors and resistors around the chip are ok.
        Not that a resistor was moved when unsoldering.
          Hello to all.
          I have Lenovo Thinkpad T470S with Supervisor Password.
          Read a lot of the post on here and I'm not sure what to do..
          Do I need to remove the bios and put on some programmer to get the bios dump and patch it, then to flash it (as it was written on the post #1) ?
          Or should I get a bios dump file with some software then patch it and flash it?
          I do not have a hardware programmer, can I use another patched bios file if there's any here available?
            Hi pleas can any one help me to unlock this lenovo l460 one chip bios
              Reset NVRAM
              So disconnecting the battery didn't help.
              The chip was read on the board using the clip.
              All resistors seem to be in order.
                Try ...
                  So no matter what I do, the result is still the same.
                  I unplugged the memory and it doesn't work.
                  Removed the batteries and it doesn't work.
                  I only have to beep 5 times 2 times in a row.
                    Try this file from me ME Region Clean that work for me .....
                      Well
                      It doesn't work any other way
                      The advice will beep but it will start soon.
                      it wanted to set password and id.
                      But now it only writes ... To interrupt normal startup, press enter.
                      And nothing
                        Whoah.
                        Everything is in order.
                        After your edit, I loaded back my original BIOS and it's ok.
                        It no longer needs a password and runs.
                        Big thanks.
                          I tried the autopatcher on E485, but I got a crc error message when I trying to enter the BIOS.
                          Could you please patch the the original?
                          Thanks,
                            Thanks,
                            Try this one.
                            all donations are welcome,
                              Try ...
                              Hi friend i test this dump but the machine wont start only green led no fan pleas any sol
                                sir not work this patcher please guid me
                                  Originally posted by hardware1 View Post
                                  Try this one.
                                  Thanks,
                                  Unfortunately I am still having a bad crc message. Same as with the patcher.
                                    Try this file ...
                                    ME Clean from your file ...
                                      Hi all
                                      I bought a Lenovo X390 Yoga (Model 20NQ-S1C400) with unknown Supervisor Password on BIOS.
                                      I was able to read the BIOS dump with a CH341A and autopatched the file.
                                      Unfortunately, the patched BIOS doesn't work. The laptop just keeps beeping at startup and the screen is black.
                                      I repeated dumping the original BIOS and checked that the content of the files is the same. --> The dumped BIOS is correct.
                                      Writing again the original BIOS, the Laptop boots but I'm still not able to enter BIOS (because of the Supervisor Password).
                                      Here's the output of the autopatcher:
                                      autopatch "C:\Users\...\original_bios.bin"
                                      Using UEFIReplace to inject 2 DXE drivers...
                                      [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                                      [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                                      Looking for volumes to patch...
                                      [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
                                      Not found... Skipping.
                                      Done.
                                      PATCH FILE: original_bios_PATCHED.bin
                                      Good luck.
                                      Can anyone help me?
                                      What means the constant beeping at startup with the patched BIOS? Is the CRC wrong?
                                      Thanks in advance.
                                      Regards, M. Erni
                                      Hi all
                                      I bought a Lenovo X390 Yoga (Model 20NQ-S1C400 with i7 8th generation CPU) with unknown Supervisor Password on BIOS.
                                      I was able to read the BIOS dump with a CH341A and autopatched the file (https://www.badcaps.net/forum/showthread.php?t=87588).
                                      Unfortunately, the autopatched BIOS doesn't work. The laptop just keeps beeping at startup and the screen is black.
                                      I repeated dumping the original BIOS and double checked that the content of the files is the same. --> The dumped BIOS is correct.
                                      The BIOS chip is MX25L25673G
                                      The sticker on the mainboard indicates WKS FRU: 02HM794
                                      It's a 8th generation i7 Intel CPU inside
                                      Can anyone help me and remove the BIOS Supervisor Password?
                                      Thanks in advance.
                                      Regards, M. Erni
                                        Try this file ...
                                        btw: BIOS chip is MX25L25673G.
                                          Originally posted by mauri99 View Post
                                          Hi all
                                          Done.
                                          Good luck.
                                          Can anyone help me?
                                          Thanks in advance.
                                          Regards, M. Erni
                                          Sorry this will not work Yoga X380 yes AUTO-Patcher Yoga X390 no.
                                          Only goes from the 4th to the 8th Intel generation.
                                          The BIOS will have a self-healing function because of the beebs only.
