Asus x555ld rev:3.6 bİos
  • sonerpc
    • Oct 2015
    • 34
    • turkey
    Hi everyone. problem asus x555ld rev: 3.6 motherboard stays at 0.40 amps and there is no display. it is a model with onboard graphics card. please want a solid bios.
    case code: x555la-dm3014t
  • basic
    • Oct 2017
    • 229
    • 86357289244
    Re: Asus x555ld rev:3.6 bİos
    try this
    • sonerpc
      • Oct 2015
      • 34
      • turkey
      Originally posted by basic
      try this
      When I wrote the first bios, it gave an image even if it was late, it reached 0.58 ampere. But when I restarted it later, the image did not come.
      • peste
        • 13451
        • ROMANIA
        post the original bios
        • sonerpc
          • Oct 2015
          • 34
          • turkey
          https://www.dosya.tc/server30/xijcur..._bios.rar.html
          original bios thank you
          • peste
            • 13451
            • ROMANIA
            orig + Asus site update extract
            • sonerpc
              • Oct 2015
              • 34
              • turkey
              Unfortunately, it did not display. And after 0.40 amperes, the device cuts off the power. I could only get a picture once in the bios given by the friend with the basic nick. Do you have a chance to edit it?
                • 21692
                Do you have a white /green sticker on the motherboard with a model number on it. Post some pictures
                • peste
                  • 13451
                  • ROMANIA
                  try..
                  • sonerpc
                    • Oct 2015
                    • 34
                    • turkey
                    thank you bro.n the meantime, do we need to write ite8585. Or does it draw on each bios, even if ite8585 is full
                      • 21692
                      i didnt say on the case bro . "white /green sticker on the motherboard"
                      • sonerpc
                        • Oct 2015
                        • 34
                        • turkey
                        try..
                        my problem continues the same. two bios you provided shut down after 0.40 amps and no display
                        • sonerpc
                          • Oct 2015
                          • 34
                          • turkey
                          ok brother sorry.
                          I wrote how many bios I was able to get an image once. I don't understand why asus is making such a mess.
                          no external video card on the motherboard
                          i3 5010u
                            • 21692
                            Try this bios .
                            • peste
                              • 13451
                              • ROMANIA
                              ok brother sorry.
                              i3 5010u
                              try..
                              • sonerpc
                                • Oct 2015
                                • 34
                                • turkey
                                Try this bios .
                                unfortunately it remained at the same 0.43 amperes and there is no image. I make ite8585e blank and write bios.
                                maybe because the software in ite8585e is problematic.proplem....
                                Believe me, I can not understand. Maybe I wrote 15 bios I could only get one image from one
                                • sonerpc
                                  • Oct 2015
                                  • 34
                                  • turkey
                                  try..
                                  the same problem persists. I was able to get an image once in the first bios you shared, it increased to 0.58 amps and entered the bios screen
                                  • peste
                                    • 13451
                                    • ROMANIA
                                    the image appeared on the bios from which post ??? and what happened after ???? ...
                                    • sonerpc
                                      • Oct 2015
                                      • 34
                                      • turkey
                                      Thank you so much for your attention. I received images in the bios you shared first, it increased to 0.58 amps. When he turned it off and on again, it remained at 0.40 amps and there was no picture.
                                      • peste
                                        • 13451
                                        • ROMANIA
                                        try it again and see if the same happens ..
