HP Elitebook 1030
  • e900
    • Dec 2019
    • 26
    HP Elitebook 1030
    Hello
    Please help unlock bios password for HP Elitebook 1030.
    I extracted soldered to mainboard and connected to ch134a usb, booted via linux mint / flashrom with disconnected battery but power to mainboard by power adapter.
    I tried to -v verify but failed a few time, i extracted the bios x3 time OK and all have the same size so i think maybe ok.
    Someone please confirm if the bios can be unlocked and is OK?
    Thanks.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: HP Elitebook 1030
    Originally posted by e900
    Hello
    Thanks.
    Same size =/= same content. You can compare content of the files with Total Commander or HxD. So first compare those 3 files, and if they are same will be safe to say that the dump is read OK, and you have a good backup. So before erasing the chip and programming new dump always do this or you will have a big problems.
    P.S. Just checked the file - dump is bad.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • piernov
      • Jan 2016
      • 4437
      • France
      UEFITool has trouble reading the backup so I'd say it is bad.
      In any case I never be confident working on a BIOS in a situation where verify fails.
      I personally always desolder the chip and don't recommend working with a CH341A as there seems to be a lot of issues with those (and in particular related with 128Mb or more SPI ROM).
      • e900
        • Dec 2019
        • 26
        Thank you, im new to this, im happy to try and learn, especially when steps and guidance is available
        I also tried UEFITOOL and got some errors, but googleing them shows they maybe generic errors. Although im not sure where to start on UEFItool but did you manage to locate any password or anything about it?
        I may get the chip unsoldered.
        Im using the CH341a programmer, with the 3.3 adapter?
        What do you recommend working with or using? Im doing this the first time for a friend.
        Is there a way to flash a clean bios? start fresh? What can i do next? or do you recommend next to do?
        Heres a picture of my setup
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          This is always better rather to work with the chip in circuit.
          CH341a is a 3.3V, so if your bios chip is 3.3V you don't need any adapters
          Use Windows based program. Try AsProgrammer with CH341A support
          DOWNLOAD LINK
          Get a good bios dump first, this is a must. Than upload the file here and someone will remove the password for you. No other way, "start fresh" and so on.
          That's it.
          • e900
            • Dec 2019
            • 26
            DOWNLOAD LINK
            That's it.
            Sorry I meant the 1.8v adapter? I have the 1.8v adapter also plugged in the ch341a usb...I read on a post (winraid?) that the chip may overheat if the incorrect voltage is applied to it via usb and to use the 1.8v.
            How can i find out if my chip is 3.3v or if I need to use 1.8v?
            Do you recommend to try direct on the CH341a direct?
            I will try the windows programmer to.
            Thanks again.
            • e900
              • Dec 2019
              • 26
              My chip is a 128 25q128jvpq + 25q64jviq
              I cant find this in ASPROGRAMMER?
              Flashrom in linux detects it as a "W25Q128.v" 16384 kb SPI
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Just power up the board and measure voltage on pin 8, and you find out. Red probe on pin 8, black probe on grond (or on pin 4).
                • e900
                  • Dec 2019
                  • 26
                  Think im getting somewhere, before I begun reading the chip, the computer would not power on, the power light would blink continuously.
                  Since then i removed the 1.8v adapter and plugged direct to the ch341a usb programmer and the machine now powers on, fans spins. which is a good sign, better than the continuous dead feeling i had from before.
                  Im now trying to backup and im getting Error: file backup3.bin could not be written completely. Failed.
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    W25Q128JV must be 3.3V but take the chip voltage with the multimeter.
                    If it's 3.3 than select second from the drop down menu (W25Q128FV)
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      Read the chip first! Correctly! Take a good dump! Verify the dump!
                      And then try to write! And write correct dump after someone of us edit and remove the password from your backup!
                      Read the whole topic again. Carefully!
                      • e900
                        • Dec 2019
                        • 26
                        I appreciate your help and patience with this.
                        In Flashroom im using the -r command, (read) , im not writing anything to the bios.
                        I tried to read the chip with ASPRorgrammer and im getting Error connecting CH341(-1)
                        I have checked device manager and the ch341a is listed with no errors.
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          To receive such an error means you didn't connect the chip to the programmer correctly.
                          What is used for the connection - clip, wires?
                          Did you measure the chip voltage?
                          What is the voltage measured?
                          • e900
                            • Dec 2019
                            • 26
                            got it! I think I was running out of free space on the disk / usb, im using live CD mint.
                            Attached the bios. I tested opening the bios is uefi tool and it looks good, no errors compared to the ealirer one i posted.
                            Please let me know?
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              Please let me know?
                              Take the dump once again so I can compare both files.
                              I receive an error reading the dump file with ME Analyzer, which means the dump is not OK
                              Code:
                              Error: Detected CSE Extension 0x03 with wrong Partition Hash at FTPR > FTPR.man!
                              Take the dump with AS Programmer also.
                                • 21692
                                Remove the pass and clean the ME ,it should be ok .
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  Let's wait to have a second file to compare, password and ME region are easy, the important thing is to make sure the bios file is read correctly. I'm just not sure what he's doing there.
                                  • e900
                                    • Dec 2019
                                    • 26
                                    Thanks guys,
                                    Running ASProgrammer now, just reading at the min
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      Thanks guys,
                                      Ok great, take your time don't hurry.
                                      • e900
                                        • Dec 2019
                                        • 26
                                        all done, did a verify with ASProgrammer and all ok (no errors)
                                        Took x2 dumps, both on ASProgrammer.
                                          HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:27 AM
                                          HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 06:40 AM
                                          09-06-2024, 05:33 AM
                                          HP EliteBook EliteBook 1030 G1 Notebook PC (ENERGY STAR) Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 1030 G1 Notebook PC (ENERGY STAR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 1030 G1 Notebook PC (ENERGY STAR) boardview and EliteBook 1030 G1 Notebook PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 05:30 AM
