Hp elitebook 840 g5 bios password
    Originally posted by SMDFlea View Post
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    RCUnlocker can delete computrace lock? Sorry, this is my first time encountering this. The laptop was blocked for organization; the laptop was scrapped. I was able to fix it, it did not turn on, but I see a blockage when installing windows.
    mb: computro 6050a2945601-mb-a01(1a)
    HP Elitebook 840 G5
    sku 2FA66AV
    UID 9B7337C7-0033-9973-5E10-38362DDAF283
    BIOS Q78 ver. 01.22.00 09/15/2022
    sn 5CG83260G2
      HP Elitebook 840 G5
      sku 2FA66AV
      sn 5CG83260G2
      Install windown 10 home.
      Become a Badcaps supporter
      Thanks to all supporters.
        HP Elitebook 840 G5
        sku 2FA66AV
        sn 5CG83260G2
        upload your main bios. and serial number here.
          I already did it, look up please. sn 5CG83260G2
            I already did it, looj up please. sn 5CG83260G2
            Send to you
              Originally posted by minhdigital View Post
              Send to you
              What changes have you made?
              As I understand it, "Windows Autopilot" is sitting in my dumps.
                Send to you
                Many thanks to you. With the help of your dumps and BIOS Configuration Utility (SP100599), I won the battle with Windows Autopilot Lock. Everything works fine!
                  No results. Only programming spi chips made effect.
                    Request for unlocking my bios:
                    HP EliteBook 840 G5
                    ProdID 2FA64AV
                    SN# 5CG9245ZLH
                    I tried HPUnlocker withous success (password is still there).
                      HP EliteBook 840 G5
                      ProdID 2FA64AV
                      SN# 5CG9245ZLH
                      First boot press F10 reset bios to factory defaults, 2nd boot reset security settings to defaults.
                      search here bios config utility in forum in case you don' know.
                      Use BCU to fill these DMI INFO
                      Serial Number: 5CG84925QJ
                      Product Number: 2FA62AV
                      CT Number: PGWHN00WBBL7HY
                      Description: HP EliteBook 840 G5
                      build_id: 17WWCSBT602#SABU#DABU
                      Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqgdhKhkjh.gD
                      MAC Address: E4-E7-49-20-66-B0
                        Does not work (black screen). Just noted your product number differs from mine (don't know if this matters).
                          the product number is extracted from your bin. upload the EC 16mb or use RC unlocker D.I.Y .
                          did you verify this main bios bin after reading?
                          ec is found at the back of the board you need to disassemble.
                            Sorry, I did something wrong, I attached the correct file now. Thanks for patience.
                              Serial Number: 5CG9245ZLH
                              Product Number: 2FA64AV
                              CT Number: PGWHQ00WBCE59A
                              build_id: 17WWCSCT601#SUUZ#DUUZ
                              Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfXhKhkj4jh.fR
                              MAC Address: 80-E8-2C-A1-5E-C50
                              in case your wondering about this DMI info its from your dump.
                                This worked! Thank you so much.
                                  Originally posted by ashr88 View Post
                                  Thank you, I accidentally knocked this off. I've replaced it and now it's booted! Thank you.
                                  Hi . Me to i Los this resistor and i don't know his value
                                    Please help me to remove BIOS password from attached dump (32MB). Patching this dump - as rex98 did in 274 - would be the best.
                                    HP EliteBook 840 G5
                                    SKU 2FA66AV
                                    SN# 5CG9313CSW
                                    Thanks for your help!
                                      HP EliteBook 840 G5
                                      SKU 2FA66AV
                                      SN# 5CG9313CSW
                                      only flash this main do not touch the EC.
                                      follow these instructions.
                                      First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults.
                                      use BCU permanently disable the absolute there.
                                      here's your DMI info:
                                      Serial Number: 5CG9313CSW
                                      Product Number: 2FA66AV
                                      CT Number: PGWHT00WBCL3EX
                                      build_id: 17WWCSCT601#SABD#DABD
                                      Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfXhKhkjh.d7
                                      MAC Address: F8-B4-6A-E5-D5-D1
                                        Great, it's perfect. Thanks for your help.
                                        Btw which tool do you use to extract machine specific info and to patch BIOS file?
                                          there is no tool.
