Dell Precision 3520 Bios
  • Asxetos21
    • 8
    • Greece
    Thanks mcplslg123 your advice is solid.
    I could not agree more on the "don't mess with hardware unless necessary".
    I attach the original bios dump the board was on when it started dying.
    If someone could have a look for any bios corruption?
    Thanks...
    • 21914
    Re: Dell Precision 3520 Bios
    Try this bios .
    • Asxetos21
      • 8
      • Greece
      Thanks SMDFlea,
      Didn't work, same behavior.
      Can someone provide a full working dump from ALL 3 flash chips on a Dell Precision 3520 with an i7-7820HQ cpu?
      Don't care if it's password protected, i just want to see if it brings the board to life.
      UC5 is the main bios (under the fan)
      UT2 and UT6 are for Thunderbolt firmware and EC settings (next to the USB-C plug).
        • 21914
        Your backup bios had corrupt ME firmware,i only cleaned it, i`ll post another bios with the latest update merged as there could be corruption in the bios region too.
          • 21914
          New bios . service tag: CFXCSQ2 .Give it some time,it may reboot a few times .
          • Asxetos21
            • 8
            • Greece
            No luck, same thing.
            On 1st DC connection, the power light goes on for 3-4 secs and then it stays off, the battery led blinks white forever.
            I left it settle for 15 mins before i tried to power it on manually (long power button press). It powers on for like 10 secs then stays off (and behavior is repeated).
            PS (correct me if i am wrong)
            To my knowledge, ME firmware is a combination of a piece of BIOS code, and a piece of firmware that is flashed directly inside the CPU when the ME version is changed in the bios.
            Plus those 2 pieces of code MUST agree (be on the same version).
            So far, all efforts on my board were done on the bios side, but cpu part of the ME-firmware must be still the same since the cpu update part needs a working board to run.
            Any thoughts on this?
              • 21914
              You have a hardware issue,i beleive both bios i posted are good.
              • Asxetos21
                • 8
                • Greece
                I will ask the community again,
                Can someone provide a full working dump (programmer readout, and unmodified) from ALL 3 flash chips on a Dell Precision 3520 with an i7-7820HQ cpu?
                It has been proven (also by me) that ANY modification on late (>2016-2017) generation Dell laptop bios can lead to similar behavior. It does not pass the built in digital signature tampering verification, so only a good readout from the same hardware will work.
                On a 2017 dell Latitude (same generation) i requested a NVME module replacement bios, which caused a "CPU failure" led code. Restoring the original dump fixed it.
                Thanks...
                • walid1992
                  • May 2016
                  • 36
                  • tripoly
                  Originally posted by SMDFlea
                  Try this bios .
                  thank you
                  bios working 100%
                  • ahkh_72
                    • Dec 2014
                    • 109
                    • Iran
                    hi
                    my laptop is precision 3520 Serice Tag : 6CGHJM2 MB: LA-E151P REV 1 (no display issue)
                    i try SMDFlea BIOS file in post 2# but no display .
                    I Attache my orginal file . can any one fix it for me thanks.
                    .Today should be different from yesterday.
                    • netboy69
                      • Aug 2017
                      • 17
                      • England
                      Dell 3520 bios dump patched, 32mb bios, setup your original service tag or a 3520 service tag, reset bios to factory, save, on next boot press alt+f to disable mantainace mode your fan will slow down and you should be ready to go.
                      • trix11
                        Dell Precision T1650 MT Workstation bricked after BIOS update
                        by trix11
                        I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                        - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                        - Dell Precision T1650 mid tower Workstation
                        - Xeon E3-1225 V2
                        - 32Gb PC3-12800E RAM
                        - 4Tb SATA HDD
                        - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                        I see now that others have experienced like issues e.g.:
                        - https://www.dell.com/community/Prec...
                        10-24-2022, 10:35 PM
                        DELL Precision 3520 Mobile workstation 3000 Specification for Upgrade or Repair
                        This specification for the DELL Precision 3520 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3520 boardview and 3520 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                        09-06-2024, 08:38 AM
                        09-06-2024, 09:23 AM
                        09-06-2024, 06:48 AM
