Originally posted by kalilinux25
View Post
Hp probook 640 g1 bios
My final solution to repair bios and restore original motherboard specific data:
1. program bios chip with dump from post 249 -> bios does not contans machine specific data
2. after powering on the motherboard it gives some error messages like in post 250 about the missing data, however it is possible to launch Windows
3. when Windows is up, apply BIOS Configuration Utility from post 254 in the following way:
3.1 start CMD as admin and,
3.2 use BiosConfigUtility.exe /get:"actual.txt" command to write all available tokens / variable into actual.txt file
3.3 use BiosConfigUtility.exe /setvalue:"token from actual.txt","new value" command -> e.g. BiosConfigUtility.exe /setvalue:"SKU Number","G3K60EZ#AKC" will program G3K60EZ#AKC as SKU
3.4 repeat step 3.3 until you set all required tokens.
In my case theese were: Product Name, SKU Number, (ENTER) Feature Byte, (ENTER) Build ID, Serial Number, Product Family, System Board CT
3.5 when finished use BiosConfigUtility.exe /setvalue:"Manufacturing Programming Mode","Lock" to lock your bios
4. shut down Windows
5. power up your machine and it should start without any warning
Thanks everyone for your help!Last edited by szakacsa195; 12-18-2023, 03:49 AM.
Need compleet new bios file for this laptop.
Have new chip purchased and will use CH341 programmer
Old bios data is not available.
I have read that a serial number must be entered in the new BIOS.
Read a lot but it is not completely clear to me with Google translate.
How can I best approach this?
Thanks,
Marcel from the Netherlands
Thread merged. Post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
Also read - https://www.badcaps.net/forum/troubl...68#post3164468
I've come a lot further.
I use NbDmiFit-2.07
I have entered the information that I think should be included
But keeps giving 2 messages.
1. Product family
2. System board CT Number
(I did fill this in)
Who wants to help me on my way because I can't get any further now.
I'm trying to add photos.
Thank you in advance
Part config file:
BIOSConfig 1.0
; Originally created by BIOS Configuration Utility
; Version: 4.0.32.1
; Date="2024/05/02" Time="04:22:03" UTC="2"
; Found 226 settings
Manufacturer
Hewlett-Packard
Product Name
HP Probook 640 G1
System Board ID
1993
Product Family
HP Probook 640 G1
SKU Number
A3009DD10203
Notebook Model
D9R53AV
System Board CT Number
PEBGU00WD7A5RWCZI
Serial Number
5CG43200RT
Product Number
D9R53AV
Universally Unique Identifier (UUID)
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Processor Type
Intel(R) Core(TM) i5-4200M CPU
SKU Number
H5G68EA#ABH
Warranty Start Date
00/00/0000
Processor Speed
2.50GHz
Sunday
*Disable
Enable
Monday
*Disable3 Photos
