Microsoft Surface Pro 3 UEFI password
+ More Options
Latest Activity
  • bramds
    replied
    Hello can someone assist me with the link to the software ME System Tools v9.5 r6 (fptw64) that i need to make a dump of the surface pro 3 bios for getting the password.?
  • peste
    replied
    Originally posted by ago92
    Hello guys,
    came up on this thread, but couldn't find anything in AMITSE. Can someone please help?
    my SN is 021449152353
    try...
    adgjl
  • ago92
    replied
    Hello guys,
    commented on 's reply
    This is not the surface book 2 thread topic. Please do not help members when they post in the wrong thread
  • shiyab
    replied
    Originally posted by William Jefferson
    Please help retrieving the password
    sufacebook2
    i5 8250U 8+256
    SN:022821691657
    hi try
  • shiyab
    replied
    surface pro 3
    SN: 059792362053
    256 GB
    Admin Password : NTj8GLnYc9l27J
  • peste
    replied
    surface pro 3
    SN: 059792362053
    256 GB
    try...
    NTj8GLnYc9l27J
  • danish8717
    replied
    surface pro 3
    SN: 059792362053
    256 GB
  • peste
    replied
    Originally posted by ricardojsafonso
    I have this information in my possession
    read the first 20 posts..
  • ricardojsafonso
    replied
    Originally posted by peste
    post the original contents of the bios chip..
  • peste
    replied
    I would be very grateful for bios password for:
    Surface Laptop 3 512GB
    SN: 047126101557
    Thank you.
  • ricardojsafonso
    replied
    SN: 047126101557
    Thank you.
    replied
    Originally posted by Kostyakv
    Hello everyone. I'm here because I have problems accessing the bios on my surface pro 6. I will be infinitely grateful if someone can decrypt the bios password. Attached is the dump I just took from FPT 11.8.79.3722.
    Please post your request along with the laptop serial number in the Surface Pro 6 topic -> https://www.badcaps.net/forum/troubl...pro-6-password
  • Kostyakv
    replied
  • JBPL
    replied
    That was superfast! Thank you!
  • hoaca388
    replied
    Surface Pro 3 256GB
    SN: 006607243353
    Password : 000000
  • JBPL
    replied
    Surface Pro 3 256GB
    SN: 006607243353
  • TodayTommy
    replied
    Originally posted by Ziome3eknh
    on version v9.5 r6 it shows that I do not have administrator rights and cmd is enabled with administrator rights and that it cannot load pci drivers for access in windows. I suppose that this may be due to the fact that the system is started from usb. However, when opening the installation from a pendrive I cannot install it because the partition cannot be set, an error is displayed and the shortcut alt + r does not work, I can only enter repair mode and there in cmd but there is a boot partition X and when I want to switch to the pendrive the command cd C:/ returns to X: again and I do not know how to bypass this, I am out of ideas. I do not want to unglue it because the screens in them are such that 80% crack when ungluing.
    I put the folder that contains the fptw64.exe directly in C: drive. From there, type cmd in your taskbar search and right click "Run as administrator".
    Then type cd c:/foldername to switch to that folder (replace foldername with the name of your folder; simplify it if it's too long to type)
    then run the command to dump:
    fptw64.exe -BIOS -D yourbackupname.bin
    (yourbackupname being whatever you want the dumped bin to be called; name it something easy and you will find it in said folder)
    Also, I did mine on a fresh clean install of the official SP3 Windows 10 recovery image. If you cannot afford to lose your current OS and it doesn't work, consider perhaps creating a temporary partition in which you can perhaps install a clean copy of the stock Windows 10 image.
  • TodayTommy
    replied
    try....
    2i2m9c5
    Thank you, it worked perfectly. I reverted to the stock image and was able to dump the bios from Windows itself, just incase this information is a key part of the process.
  • peste
    replied
    try....
    2i2m9c5
