lenovo 320-15iap
    Re: lenovo 320-15iap
    Originally posted by peste View Post
    try
    hi sir I tried your bios bin for DG424/DG524 NM-B301 Rev 1.0
    Is this compatibel to each other?
      try post #4...
        try post #4...
        After falshing it has no display
          I replaced my bios chip from aliexpress, it program successfuly , based on expired can it be caused why I dont have display beacuse I used a replacement bios chip, Hope someone can Answer.
            if the bios doesn't work, you might have another problem... check ram memory, video chipset, LVDS cable, display, check voltages, etc.
              I already posted a new thread sir hope you aca cehck it out thanks
                Originally posted by hoaca388 View Post
                Your serial number ?
                https://www.badcaps.net/forum/showth...21#post1217721
                Please help me sir post #5
                  i tried files in this thread with no luck /////mine is using CPU AMD A5 ///ori file is attached////mobo code isG425/DG525/dg725 NM-B321
                    Please alaywas provide a serial numebr of the laptop
                      Write your Device Model and Serial Number.
                      all donations are welcome,
                        sorry for that as serial sticker was removed
                          I don't know why did you choose this thread to post your request? It's for devices which contain Intel CPU not AMD.
                          You should create a New thread named with your Motherboard, and write your device details as you can, such as (CPU, Screen Inch or anything that can help someone to give you the correct BIOS).
                          Your dump file contains Serial Number, I can move it but I can't know it because it's encrypted. Maybe someone else can decrypted it (I don't know).
                            thanks for help
                              Can you help me with identifying the password from this dump? I've read the WINBOND chip fully on programmer. Owner forgot the password that was set 4 years ago..
                              Lenovo ideapad 320-15IAP , Pentium N4200 CPU.
                              Thank you and best regards,
                              Robert
                              Robert
                              Sorry SMDFlea,
                              here is the SN: PF10J3Q7 .
                              Let me know if you need anything else.
                              Thank you,
                              Robert
                                Sorry SMDFlea,
                                Thank you,
                                Robert
                                Try
                                  Originally posted by Blaze Tech View Post
                                  Try
                                  Thank you,
                                  Will test and report back. I guess it needs to be written on programmer, right?
                                  Best regards,
                                  Robert
                                    Thank you,
                                    Best regards,
                                    Robert
                                    Yes with programmer
                                      Okay, wrote the flash, all good and can enter the BIOS now, but I seem to have lost the motherboard serial number and Lenovo SN. Isn't there any option to clear the password without losing those?
                                      Best regards,
                                      Robert
                                        Best regards,
                                        Robert
                                        https://www.badcaps.net/forum/troubl...12#post1643312
