pls Bios HP Probook 450 G5
    Re: pls Bios HP Probook 450 G5
    450G5
    Please, Ideas or suggestions on that? Any kind of help is appreciated.
      Originally posted by macl View Post
      450G5
      What problem do you have???..
        I bought a used Laptop. Unfortunately BIOS setup is secured by password, but I need to enable Virtualization Technology (VTx) & Virtualization Technology for Directed I/O (VTd) on my Laptop.
        Automatic BIOS Update Setting are disabled
        Update BIOS via Network is enabled (but needs still pw)
        Legacy Support is disabled and Secure Boot is enable (suckz also)
        I've no idea how to change BIOS settings without the Admin password. Also I can't boot any native cracker software (tools included in Hirens or Kali for eexample), because secure boot Option.
        So I'm looking for a possibility to flash BIOS without extracting the Chip from Board, because I don't have the hardware ans the knowledge to flash the EEPROM and I'm also not good in disassembling and assembling microelectronics, but didn't found any alternative solution till now.
        Maybe u've an idea?
          Maybe u've an idea?
          you have to remove the chip from the board and read it, otherwise you can't..
            Get yourself a cheap Ch341a programmer, less than US10, with clip preferably. program it with asprogrammer. Take out the CMOS battery if it has one. Identify your BIOS Chip, usually it reads Windbond or MX and has lettering like W25Q128FV. Read and save first reading, close programmer and start again, do a second read and save. Again close program, unhook everything and start again, do the third read and save. Download WINHEX, a hex editor, and compare your saved readings, two at a time. They should all be identical, otherwise, do some more readings and pray to the internet gods you got it all right. Remember that is your backup in case something goes bad. Rar or Zip the bin file you got and post it here, someone will help you.
            I myself rely on the TL866II medium priced, and a 200mm adapter for legged chips and a double WSON adapter, 8X6 and 6X4 for legless chips.
              please clear this bios SERVICE TAG 5CD8323C8Z
                Your file now is Configured. try it.
                all donations are welcome,
                  Can please someone unlock this bios (see attached file) for hp probook 450 G5
                  Thanks in advance
                    Thanks in advance
                    Here's your unlocked file, try it.
                      bad
                        I am uploading my old bios, its not powering.
                        i tried the above bios but very late display it takes 2mins for the display to come.
                        can someone help me to fix my bios please. thanks
                          Here's your new bios file, try it and let me know the results.
                            hardware1:
                            Thank you very much it's working good
                              Hello guys,i need help with my bios, laptop turning on, fan spinning fast and no display
                              below its my original file
                                HP ProBook 450 G5 Notebook PC
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  good afternoon. please help me fix my bios. black screen. the fan is working at maximum. thanks
                                    Here's your New Bios, try it and give me the results.
                                    Serial Number: 5CD7440LF1.
                                      could any one please help me to me region this bios file
                                        Have you tried it yourself,there are some guides you can follow
                                        How to clean ME/TXE region
                                        https://www.badcaps.net/forum/showpo...41&postcount=3
                                          everything does not work, the same capslook flashes 6 times
