Need Bios ba41-01327a
  • seba666
    • May 2018
    • 30
    • arrrggg
    hi.. i need a dump for a scala 14ul rev mp1.0
    ba41-01327a
    thnxxx!!!
  • Carlos ivan
    • Aug 2019
    • Perú
    Re: Need Bios ba41-01327a
    I also need it
    • peste
      • 12600
      • ROMANIA
      Originally posted by Carlos ivan
      Yo también lo necesito
      post the full name and model of the laptop and the backup of the bios.
      • peste
        • 12600
        • ROMANIA
        Originally posted by carloscolombo
        necesito bios samsung rv 410 scala-14ul ba41-01327a gracias
        post the bios backup.
        • superhache
          • Nov 2018
          • 46
          • Argentina
          hello, this is a dump from a water damaged board i hope it is ok, and let me know, thanks
          • MrEmiriv
            • Mar 2016
            • 14
            • Argentina
            It works!
            Gracias che
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • cekcons
              g1 assassin Rev 1 bios dump - main and backup needed
              by cekcons
              main and backup ic dead so i cant post corrupt bios cause its 01 all over.
              thanks
              01-23-2024, 03:26 AM
            • grimacelord
              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
              by grimacelord
              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
              Motherboard model number: DA0PAMB46A1 REV: A
              Secondary motherboard model number: 0PAB
              SKU: 685K4UA
              Serial number is: 5CD3223BJP
              Recently reflashed this laptop with latest BIOS and once...
              05-07-2024, 08:06 AM
            • DynaxSC
              Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
              by DynaxSC
              I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
              It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
              I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
              11-06-2022, 05:22 PM
