Need bios G6 2112SIA DAOR33MB6EO REV E
  • dylen
    • May 2017
    • 173
    • Mauritius
    Please help needed. i've got a laptop G6 which when power button press the fan spin for five seconds and stop, pressing the power button again with no effect, should remove ac power for twenty seconds and then reinsert adapter and press power button with same effect as above and no post.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Need bios G6 2112SIA DAOR33MB6EO REV E
    Not likely to be i bios issue though you can try. Try changing PQ50 near dc jack. Had same symptoms on a quanta R33 and replacing it did solved the problem.
    • dylen
      • May 2017
      • 173
      • Mauritius
      Thanks, will try and revert back.
      • dylen
        • May 2017
        • 173
        • Mauritius
        No 3v on NBSWON, i.e power on, pin 1,2,3 of power button there is 3v, if short pin 1 to pin 4 of power button it starts.What could be the fault?
        • dylen
          • May 2017
          • 173
          • Mauritius
          Reflow pch & replace C59 did the job, it was indeed not a bios issue as stated by mcplslg123. Thanks
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
            by Vesko356
            08-11-2023, 03:27 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
