100% working MacBook Pro (13-inch, Late 2016, 4 TBT3) BIOS dump
can someone remove EFI Lock please? Thanks in advance!
SN: C02T7121GTDX
Motherboard Model: 820-00239-A
EMC: 3071
Attached FilesLeave a comment:
Macbook Pro 13 inch late 2016 (not sure) with touchbar
A1706
motherboard model: 820-00923-A (i saw it now its the wrong one rip)
emc: 3163
bios attachedAttached FilesLeave a comment:
post S/N, full name and model, motherboard model,EMCpost the contents of the bios chip even if it is corrupted..,etc.Leave a comment:
today I would like to share with 100 % working MacBook Pro (13-inch, Late 2016, 4 TBT3) BIOS dump. A1706, 820-00239-09.
Some notes:
1) ME region is not cleaned! Clean it by yourself, or system will not work properly.
2) The serial was replaced, look for QWASZXERDFCV and replace it to your serial, in this dump in two places.
Best regards,
Raimondas
i did write this bios.bin to my macbook and it didnt boot, then i did write the original i did backup but still the same.
no fan spinning nothing.
mine is with touchbar can this make any problem?Leave a comment:
found the issue. application was not doing the erase correctly so i tried more.Leave a comment:
hi, i need help.
was removing pass from efi and when i wrote unlocked file, device does not turn on. not even with original dump. both attached. macbook pro 13" a1706 emc 3071 sn C02TP187HF1R.
maybe dump is corrupted. any suggestion is welcome.Attached FilesLeave a comment:
buil
clear
auto_awesome
Có phải ý của bẔn là : build giúp tÓi
14 / 5.000 Kįŗæt quįŗ£ dį»ch
Kįŗæt quįŗ£ bįŗ£n dį»ch
build help meāAttached FilesLeave a comment:
Hello! Help remove efi bios password. A1706 820-00239-A C02T10C0GTDXAttached FilesLeave a comment:
https://www.badcaps.net/forum/troubl...ore-postingā .Leave a comment:
Can someone help me clear me bios a1706 820-00239-A. thank you very much
Re: 100% working MacBook Pro (13-inch, Late 2016, 4 TBT3) BIOS dump
i deleted the $SVS part. but the FMM is still on. can i unlock FMM on this model?Leave a comment:
Thank you so much !!Leave a comment:
H i , would you please be able to remove the password on this bios ?, many thanks if you can
a1706 ,SN C02T2ECKGYFHAttached FilesLeave a comment:
by samstownHello,
This special tool from Apple is used to recover data from Macbook A1706. I've been using it for a while but it stops working. When connecting Thunderbolt 3 between the tool and working Macbook, Macbook should prompt "new device detected, allow or not"... but it doesn't.
Has anyone ever experience this ? It's not a cabling or power supply issue, some IC have stopped working but not sure which one. Probably the one that manager thunderbolt 3
Claude... -
by envymHi everyone!
I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
Channel: Schematics and Boardviews
10-22-2024, 02:37 AM -
by rilleyHello everyone,
I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
And the resistor L4004 is literally burned.
From what I see from the schematics, it does not affect any other rails, only the connection to the display... -
by zaler808Hi guys, this my first post but i want to be brief about it, i recently got a MBP L2013, the problem was that after some use the macbook shutted down randomly, at first i suspected to be the battery, and after connecting it with the charger i noticed that i didn“t shut, but after an hour or so it shutdown, after that i started searching a solution to my problem, but my brother tried to help me to find the problem and it that process to replicate the problem he reproduced a 4k video in multiple tabs and not much time after the macbook shutdown to never power again, what i noticed was that the...05-23-2024, 05:17 PM
- Loading...
