Trouble reading BIOS on Dell Precision 3571
  • bk304
    • Jan 2025
    • 22
    I am trying to read the BIOS chip installed in a Dell Precision 3571 so I can remove the administrator password. Processor is a 12th gen i7. The service tag ID is 7QV7VL3 (8FC8).
    So far, I have not been able to read the chip. I have done this a few times on older 8FC8 BIOS chips and have not had a problem. The BIOS chip is an XMC XM25QH256CXIQ (U2502 marked on the board). I am using a T48 (TL866-3G) programmer and a pogo pin probe for the WSON8 chip. The programmer auto ID is identifying the chip correctly but the ID check comes up FF FF FF. It should be 20 40 19. Pin detect is OK. I tried reading the chip without the ID check and it came up blank. Yes, I did test that the computer was working before I took it apart.
    I am trying to avoid removing the chip from the board. I am not sure if I am doing something wrong or have clumsily killed the chip.
    My questions are:
    Could the chip being soldered onto the board be causing a problem reading the chip?
    I do not have a BIOS for this computer if the chip is bad, Will a copy of the BIOS from another 3571 work in this one?
widgetinstance 457 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
