leonovo ideapad 3 15alc6
  • roixijram
    • May 2019
    • 50
    • tunisia
    i need bios
    matherboard;hs461&hs561&hs761 nm-d521 rev 3.0
    sn:pf40424j
    The device is working and nothing appears on the screen
    my bios
    cpu: amd rayzen 7
    my bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 11673
    Originally posted by roixijram
    i need bios
    sn:pf40424j
    my bios
    cpu: amd rayzen 7
    my bios
    IdeaPad 3-15ALC6 Laptop - Type 82KU
    • roixijram
      • May 2019
      • 50
      • tunisia
      Didn't work
      • hoaca388
        Badcaps
        • Jan 2022
        • 11673
        Didn't work
        Check hardware.
        • roixijram
          • May 2019
          • 50
          • tunisia
          Check hardware.
          I charged the bios with another one, but there was a difference in the processor and it worked, so it came out with a message saying that the processor was different on the device.​
          • hoaca388
            Badcaps
            • Jan 2022
            • 11673
            Then check to see if the serial number pf40424j is yours. Please provide the bios link.
            • roixijram
              • May 2019
              • 50
              • tunisia
              its a true sn
              i flashed with this
              • hoaca388
                Badcaps
                • Jan 2022
                • 11673
                its a true sn
                i flashed with this
                Here
                • roixijram
                  • May 2019
                  • 50
                  • tunisia
                  Here
                  thanks, working
                  • zmeutul
                    • Apr 2018
                    • 17
                    its a true sn
                    i flashed with this
                    Working. Thank you
                    • djharold
                      • Aug 2015
                      • 241
                      • COLOMBIA
                      Here
                      thankyou work for me
                      • rodrigo_vargas
                        • Nov 2018
                        • 5
                        • Brasil
                        Hello everyone, I need help with my Lenovo IdeaPad 3 15ALC6 - 82MF0004BR motherboard nm-d521 rev 3.0.
                        I downloaded the BIOS GLCN66WW released on 02/19/25 directly from the Lenovo website. After installing the firmware update, the notebook stopped working. It turns on the Capslock, NumLock and ESC, show backlight on the screen, and then restarts and stays in this endless loop turning on and restarting.
                        I was able to successfully extract a backup of the BIOS using an EPROM programmer. Could someone help me revert to a previous BIOS? I don't know how this DMI thing works.
                          SMDFlea commented
                          Editing a comment
                          Thread merged.
                        • 20747
                        Here`s GLCN64WW + your DMI. Turn off bios capsule updates in bios settings, if there is that option.
                        • rodrigo_vargas
                          • Nov 2018
                          • 5
                          • Brasil
                          Thanks friend, I'll test it. Just one more question, what is the serial number that is linked to this BIOS? I ask because I had already replaced my notebook's motherboard with a new one and I never wrote down the new serial number. After re-recording the BIOS that you sent me, will I be able to see the serial number in the BIOS?
                          My notebook originally had a motherboard with a Ryzen 5 processor, but since my old motherboard failed (short circuit in the USB port), I decided to buy a new motherboard with a Ryzen 7 processor in October 2024 and everything was working perfectly until I updated the BIOS earlier this week.​
                            • 20747
                            You should be able to the serial number in the bios
                            • rodrigo_vargas
                              • Nov 2018
                              • 5
                              • Brasil
                              It worked my friend!!! Thank you very much!
                              Is there any safe method to update to the latest version GLCN66WW without bricking the motherboard again or do you not recommend trying to update again?​
                                • 20747
                                Happy to help. .GLCN66WW has fixes for some security vulnerabilities https://download.lenovo.com/consumer...s/glcn66ww.txt ,its up to you if you want to install it, you can try, and if it bricks the laptop again you can flash version 64 back with your programmer.
                                • rodrigo_vargas
                                  • Nov 2018
                                  • 5
                                  • Brasil
                                  Perfect, Thank you very much again!
                                  • Xiran
                                    • Jan 2019
                                    • 42
                                    • Qro
                                    Hi to all!
                                    I have
                                    motherboard:
                                    I´ve thing bad bios...
                                    Because turn on, but no comunicationin usb (voltage yes), no video.​
                                    • Xiran
                                      • Jan 2019
                                      • 42
                                      • Qro
                                      I´ve flash the file: GLCN64WW, without luck... same simtom, no image, no backlight, white on leds steady
                                        Lenovo IdeaPad 3 15ALC6 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad 3 15ALC6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ALC6 boardview and 3 15ALC6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-07-2024, 05:20 AM
                                        09-07-2024, 05:00 AM
