---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.β ----------------------------------------------------------------------------------------------------------------------------------------------------------
Dell Inspiron 5402-5409 and Vostro 5402-5409 models may encounter an issue where the service tag cannot be saved after reprogramming the BIOS. The solution is to use attached BIOS images. π But even after trying this, you might still encounter the same issue, right? ππ Don't panicβthe trick is to try pressing the ALT + F keys several times, perhaps up to 10 times, until you see the prompt 'Please select your laptop model.' After entering the model number, you will be prompted to enter the service tag. ππ Good luck
Hi, I need help setting the correct Service Tag in the BIOS of a Dell laptop with the following specs:
Motherboard model: MKB N TGL 8L MB 19861-1
Model: Dell Inspiron 5402 (P130G002)
Service Tag: 181SVM3
Express Service Code: 2663538699
Since the Service Tag went missing or got corrupted, I now have to reset the BIOS every time I want to turn on the laptop. I believe this might be related, and restoring the correct Service Tag and SSD recognition could potentially fix the issue.
Any help or guidance on how to reprogram the Service Tag and stabilize the BIOS would be greatly appreciated. Thank you!
merged post ...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
