So the laptop has a corrupted bios, i want the A15 BIOS file so i can flash it directly on the chip, as well as the EC bin File, i found these files here however the EC file was 1024KB, i think it should be 128KB to fit the chip if im not mistaken. And the BIOS version is not what i needed.
post S/N, full name and model, motherboard model, etc.
post the contents of the bios chip even if it is corrupted..(main+EC)
CPU: i7-3630QM - Ivy Bridge
Also it has the 3d display 120hz, so it can't ever run on the integrated GPU (not sure how that info is relevant)
Backup (corrupted) contents attached, what makes me think they're corrupted, or at least one of them is, the power cord unplugged while installing BIOS and giving 7 beeps on startup ever since.
Also it has the 3d display 120hz, so it can't ever run on the integrated CPU (not sure how that info is relevant)
write only the 8MB chip..the other chip remains the same...
Thanks for the prompt response.. quick question before installing it I'm just making sure, did you check the other one (EC file) ? does it look normal?
