need asus a42f bios bin file
  • innocentforeign
    innocentforeign
    • Jun 2013
    • 172
    • KSA
    hi friends
    i need asus a42f bios file if any one have please share
    mv-494v-0
    thank you
  • innocentforeign
    innocentforeign
    • Jun 2013
    • 172
    • KSA
    Re: need asus a42f bios bin file
    there is no display coming in asus a42f when plug the charger all led lights on and laptop fan spinning slowly after 10second fan spin very fast and no external display coming . change the cpu . ram . flash bios . but problem still
    any idea ???????????
    • innocentforeign
      innocentforeign
      • Jun 2013
      • 172
      • KSA
      friends i really need help
      first i change the processor then flash bios display working good but create another problem laptop sometime work sometime no power . i need original bios file please
      i will be thank full..
      • Ramee
        • Jul 2014
        • 218
        • Israel
        Your cpu is getting hot so fast. Check caps and inductors around cpu socket, if they are all ok, reflow the cpu socket, but use liquid flux only.
        • innocentforeign
          innocentforeign
          • Jun 2013
          • 172
          • KSA
          thank you Ramee for reply
          caps and inductors around cpu socket are all ok . sometime laptop work normally
          if shut-down laptop and unplug charger. then plug charger again laptop not start-up no led on...
          i will try to reflow the cpu socket and inform you
          • Ramee
            • Jul 2014
            • 218
            • Israel
            May be you got the wrong bios file, why don't look around first, may be you'll find somewhere. Reflow the cpu socket is just a 2nd option.
            • Ramee
              • Jul 2014
              • 218
              • Israel
              Try this, extract it and load it up to your programmer.
              • alihomee
                • Dec 2012
                • 1574
                • malaysia
                take out the bios chip then clean the prints and put it back again properly
                • innocentforeign
                  innocentforeign
                  • Jun 2013
                  • 172
                  • KSA
                  clean the prints of bios chip and put it back again properly .
                  now laptop working fine
                  i really appreciate your help Ali & Ramee
                  & thanks a lot both of you ...........
                  • Ramee
                    • Jul 2014
                    • 218
                    • Israel
                    Glad to hear that, another experience from you guys. Good job.
                    • Sebastian Codrean
                      BIOS file for ASUS F542UN laptop
                      by Sebastian Codrean
                      Hello to all of you! I need help with a BIOS file.
                      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                      02-20-2025, 10:25 AM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • caglarec2268
                      Asus X515EA Bios File Please
                      by caglarec2268
                      merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                      Now "please follow the steps below to recover your bios" text remains on the screen
                      I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                      laptop model x515ea-bq945w
                      s/n: R4N0CV02K527148
                      CN:HWFB
                      Board model; ASUS X415EA R7.0
                      bios chip: GD25Q128...
                      11-27-2024, 03:51 AM
                    • wakethesleep1111
                      Bios File Needed for asus tuf15
                      by wakethesleep1111
                      Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                      05-27-2025, 10:56 PM
                    • rickjansen01
                      Asus FA707 corrupt Bios File
                      by rickjansen01
                      Hello Guy's
                      Can somebody help me whit this problem
                      Asus FA707 bios file is corrupt
                      sn T3NRCXCZR00Y117
                      original file uploaded
                      Regards chris...
                      04-20-2025, 07:12 AM
