Acer Chromebook C733U-C2XV,
  • mohamed mm
    • Nov 2022
    • 41
    • India
    a customer came with an Acer Chromebook C733U-C2XV he bought it from a third party, but it's forced enterprise enrollment, I tried to remove it with ( sh1mmer, USB recovery, factory reset, and powerwash) but no good.
    I hope someone helps me out.
    Thank you.
    • 21173
    Backup,serial number https://www.badcaps.net/forum/troubl...before-posting
    • mohamed mm
      • Nov 2022
      • 41
      • India
      Sorry for the late reply, I was waiting for the tools I ordered online to arrive.
      auto-detection didn't work so I had to search the IC model manually, and I didn't find my exact model which is ( GD25LQ128DWIG), so I chose ( GD25LQ128C_1.8v) and backup the bios file.
      model number: C733U-C2XV
      S/N: NXH94EK001052104497611.
      Thank you.
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Thank you.
        DA0ZAKMB6J1 REV: J looks like the bin file you give is not right
        • mohamed mm
          • Nov 2022
          • 41
          • India
          Thank you for your response
          I tried many times to desolder and resolder the chip on the programmer, but the only message I see is ( GD25LQ128C [1.8V] IC not responding / Disconnected), and when I press the chip with my finger I get the reading I attach above.
          the programmer I'm using( black is old but woking fine, and green is new),
            • 21173
            I tried many times to desolder and resolder the chip on the programmer, but the only message I see is ( GD25LQ128C [1.8V] IC not responding / Disconnected), and when I press the chip with my finger I get the reading I attach above.​
            The top adapter is meant for SOP8 and SOP16 chips, not WSON. The large ground pad under the WSON chip will be in contact with the adapter pins. Put a small piece of tape across the chip ground pad or across the adapter pins so that it doesn`t touch.
            • mohamed mm
              • Nov 2022
              • 41
              • India
              I isolated the chip with a piece of paper and tried to read it multiple times, but it didn't work. Then I used the clip and soldered the chip to the copper hooks, and I got three different readings.
              so I placed the chip back on the laptop. while reading I found something called ( "Pencil" Bypass) that could help remove the force enterprise enrollment. can I try it? and the laptop has a TPM chip will that affect the pencil bypass?
              Thank you.
              • mohamed mm
                • Nov 2022
                • 41
                • India
                Finally, I was able to extract the bios file.
