Optiplex 3070 Micro bios
    Dell Optiplex 3070
    As explained in my introduction, after many years I finally bricked one computer updating the bios (power shortage).
    Brand : Dell
    Model : Optiplex 3070 Micro
    Motherboard : 02N3WF
    Service Tag : 486KVY2
    Chip BIOS model : MX25L25673GMI-08G
    I'm new at flashing bios directly so I bought a cheap CH341 dongle.
    I tried it on an old computer and I successfully read the bios from a MX25L128Z3F chip with the SOP8 Clip.
    The I tried to read the Optiplex 3070 chip BIOS to make a backup.
    First problem, the chip is 16 pin and not 8, so i bought a 16 pin clip.
    Unfortunately I'm still not able to read the chip, as I'm not sure how to connect the clip to the programmer.
    Anyone of you have a diagram connection and a bios image for this model ?
    Thank you for your help
    Re: Dell Optiplex 3070
    For the record I tried to read the chip but the result seams strange, as is mostly empty.
      You must try to make a good backup first.If you can`t read from it then its unlikely you`ll be able to write to it either.The clips are poor and unreliable,if you can`t make a good backup then you will have to desolder the chip.
      Try NeoProgrammer software - https://www.badcaps.net/forum/showpo...6&postcount=24
      BIOS guides, methods, resources and tools
      https://www.badcaps.net/forum/showthread.php?t=103526
      1. How to dump and flash
      https://www.badcaps.net/forum/showpo...40&postcount=2
      1.1.1.6. CH341A
        Thank you, I will try to find the diagram.
        I'm still not sure how to connect to the chip, so desolder it will not help me for the moment.
          Hi, need bios for dell optiplex 3070 bios bin
          can anyone fix this file bios is corrupted ( black screen ) optiplex 3070 micro
          Ser.Tag : 2G9XF13
            Ser.Tag : 2G9XF13
            OptiPlex 3070 Micro
            Service Tag: 2G9XF13
            Become a Badcaps supporter
            Thanks to all supporters.
              I tried another power source after seeing that all its components are fine and I mean the mosfets INDUCTOR COILS AND CAPACITORS, fan does not spin does not generate video at some time the led that is embedded in the power button flashed 3 times then assemble again and nothing would happen again
              ServiceTAG: JX8CM63
              Model D10u003
              CPU: i3-9100t
              MoBo: IPCFL-CG Rev: A00
              if someone has an idea of how to locate a backup and where to get the DMI of it would be very grateful
                SMDFlea commented
                Editing a comment
                Thread merged.
              ServiceTAG: JX8CM63
              Model D10u003
              CPU: i3-9100t
              DMI . DVAR = Dell Variable 1081000 - 1090FFF
                Thanks Master SMDFlea many thanks for info, hands on work
