HP Elitebook 650 G10
    @hoaca388,
    Hello, just a precision regarding the ROM Winbond 25Q256JVEN: can it be replaced by a W25Q256JVEIN or we reaaly need the exact reference. The W25Q256JVEN doesn't seem to be referenced yet in Windbond catalog and distributors..
    Thansk for your recommendations 😊
    Best from France
      Originally posted by rex98 View Post
      serial number?
      Если я ΠΏΡ€ΠΎΡˆΠΈΠ» биос Ρ‡ΡƒΠΆΠΈΠΌ сСрийным Π½ΠΎΠΌΠ΅Ρ€ΠΎΠΌ,изобраТСния Π½Π΅ Π±ΡƒΠ΄Π΅Ρ‚?
      If I requested a bios with someone else's serial number, will there be no image?
      in English please..
        in English please..
        if the bios is ok, the DMI information doesn't matter...you will have an image...for the lack of DMI information you will receive a message at the beginning...
          Thank you!!!
            good evening, if I send you the model of the motherboard, can you assemble the BIOS for me?
              Good evening, this is a dump of my BIOS from a HP EliteBook 650 15.6 inch G10 laptop, it has a cyclic reboot without an image, I can't understand if this is a problem with the BIOS or ME, could you help me solve the problem? I'm attaching the BIOS.
                Sn - 5CD4088VWC
                ProdiD - 736W0av
                  hi every one i have hp EliteBook 650 g10 with bios password can any removed the password
                  Serial Number : 5CD408C5Z3
                  • peste
                    peste commented
                    Editing a comment
                    merged post..next time look for a thread with the name and model, motherboard model,of the laptop and post there, if you can't find it, then make a new thread..
                  #29
                  ok thank you.
                    The problem is that when you merge my post with another post, I will not get any response, unfortunately. So you can delete my post because I no longer need it now because I no longer have the device
                    • peste
                      peste commented
                      Editing a comment
                      the problem is that you have to respect the forum rules...that way we won't have any reason to keep merging and moving posts here...if you had posted where you should, maybe one of us would have had time to help you..Here, no one is obligated to help you..if you want to stop waiting, learn how to do this job, and do it yourself...
                    #31
                    hello . please unlock password . hp elitbook 645 g10 . serial . 2TK34305V7 , prod id 79B75AV .
                      first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                      use BCU. you can permanently disable Absolute lock in BCU.
                      here's your DMI:
                      Serial Number: 2TK34305V7
                      Product #/SKU: 79B75AV
                      CT Number: PSKLV038JIN0QW
                      Description: HP EliteBook 645 14 inch G10
                      BuildID: 23WWKNBZ602#SABA#DABA
                      Feature Byte: 476J6S6b7B7H7M7Q7W7m7s8uaBapaqauawcAeMfPguhKhkjhk8mEmVn7nWp9pDpapnpqprqMqz.Q4
                      MAC Address : D0:AD:08:18:92:BE
                        Dear Tam . Please unlock BIOS password .
                        HP Elitbook 645 g10 AMD .
                        serial . 5CD4055HB5
                        Prod ID :8R0Q0EC#ACJ
                        Hi everyone.
                        Can anyone help me with this BIOS? It has an administrator password to enter BIOS.
                        But for the rest it works fine. It enters Windows and does not show any hardware with errors.
                        Attached are the computer data:
                        SN# 5CD3528LD4
                        ProdID 736W6AV
                        HP EliteBook 650 G10
                        Thank you for your support.
                          Originally posted by PhonesLab View Post
                          Hi everyone.
                          SN# 5CD3528LD4
                          ProdID 736W6AV
                          here's your DMI:
                          Serial Number: 5CD3528LD4
                          Product #/SKU: 736W6AV
                          CT Number: PRVNN088JIY3UR
                          Description: HP EliteBook 650 15.6 inch G
                          BuildID: 23WWKRBZ602#SABE#DABE
                          Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPguhKhkjhk8mEn7nVpDpTpnpqprqMqz.2r
                          MAC Address : 60:45:2E:63:A2:3B
                            here's your DMI:
                            First of all, I want to thank you for your help.
                            I have copied your BIOS and entered the BIOS with F10 to restore the default values. The computer, on first startup, restarts a couple of times with the "HP WOLF SECURITY" logo and does not obey F10. After 2 or 3 restarts like this, I do get the message to enter the BIOS. But at that moment it asks me for the BIOS administrator password. Therefore, I cannot do the restore to defaults, nor restore the security options.
                            I tried to follow the procedure with BCU. The get command works and creates the bios.txt file correctly
                            According to a tutorial I followed (https://www.youtube.com/watch?v=kQJuJZNOuXg) it seems that the conventional thing is that data such as PN, SN, Feature Byte... do not appear, but for me they already appear filled in.
                            When I tried to do the set command, I got the error:
                            "Unable to process command. Password is set, but no password file is provided"/
                            "BCU return value" real="10" translated="10"/>
                            I have done the process twice just in case with the same result. Where could the error be? Thank you very much.
                              After trying with another SPI_BIOS, the computer no longer gives an image and has been left with a fixed consumption of 300mA without an image.
                              In the meantime, the firmware of several devices in the system was updated. I think there is now a corruption between SPI_BIOS and EC_BIOS.
                              I am attaching my 2 files in case someone can help me. Thank you very much.
                                Hello.
                                Please help me remove the BIOS password. I want to connect an eGPU to Thunderbolt, but I can't disable the integrated graphics. Thank you.
                                Elitebook 650 G10
                                SN# 5CD3439CS6
                                ProdID 736V1AV
                                DA0X8TMB6E0 REV: E
                                • peste
                                  peste commented
                                  Editing a comment
                                  Don't post pictures unless asked..
                                #39
                                Originally posted by astra45 View Post
                                Hello.
                                Elitebook 650 G10
                                SN# 5CD3439CS6
                                ProdID 736V1AV
                                DA0X8TMB6E0 REV: E
                                HP EliteBook 650 15.6 inch G10 Notebook PC
                                CT Number_6RGRK0AGWIMPJL
                                Serial_5CD3439CS6
                                Product_736V1AV
                                Fearture byte_476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPguhKhkjhk8mEn7nVpDpTpnpqprqMqz.2r
                                Build Id_23WWKRBZ602#SAKC#DAKC
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  I recorded your dump into a new chip. I did not select the EC reset when starting the laptop. F10 still prompts for a password. Do I need to desolder and re-record the dump again?
