old hp 550 help
  • TIXOU14
    GM
    • Aug 2020
    • 18
    • PARIS
    old hp 550 help
    Hello i have hp 550 black screen this is my dump
    i flached the bios with other file but prblm want boot in windows 7 acpi prblm bcp the bios limted i cant change to ide or ahci
    now i wanet to clean my dump
    bord 6050a2216301
  • Haker5
    Banned
    • Mar 2015
    • 65
    • internet
    Re: old hp 550 help
    please check and raport
    • TIXOU14
      GM
      • Aug 2020
      • 18
      • PARIS
      Re: old hp 550 help
      my bord is ddr3 hp 550 my problem no i cant install windows 7
      • piernov
        Compaq SR1000 MSI MS-6577 ACPI fix
        by piernov
        Compaq Presario SR1000 / SR1116FR, MSI MS-6577 (Xenon) Gamila/Giovani/Neon series
        ACPI fix!
        Yes, you read that right, the bug that HP/Compaq never fixed is finally no more, 16 years later. You probably don't care but here it is anyway.
        Bug
        Basically the bug is as follow: you want to use Linux on this machine, but it doesn't power off when you shut it down, you cannot put it to sleep, nouveau driver for NVidia GPUs doesn't load, etc…
        At boot, you may be greeted by the following message:
        Code:
          [ 0.000000] ACPI Error: A valid RSDP was
        11-30-2021, 02:34 PM
      • angel35
        Fujitsu D3445-K11 Random BSOD ACPI BIOS ERROR in Windows 10
        by angel35
        An skylake (H110) Fujitsu PC mothardboard (D3445-K11) somethimes can't start...Appear BSOD ACPI BIOS ERROR in Windows 10
        (like below picture)
        What can cause somethimes ok, somethimes not good ACPI state? Really strange
        If ACPI not good the Bios missing information from SMbus like FAN speed Voltages etc
        Wong Bios IC? Power problem?
        Wrong status:
        Good status somethimes:
        07-27-2024, 04:04 PM
      • TIXOU14
        Hp 550 beed bios
        by TIXOU14
        bord 6050a2216301...
        07-10-2023, 04:57 AM
      • kotar
        Asus X452c ACPI error
        by kotar
        can someone help me ACPI bios error of Asus X452c ,backup bios is attached...
        11-19-2023, 11:10 PM
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
