bios for HP "14-cf0001nx"
This topic has been answered.
    hi everyone
    i need dump file for this HP
    i have download Flash BIOS executable file from HP website but i dont know how to conver it to Bin file
    if anyone has this method please need his supporting to convert EXE file to BIN file .
    all the best
    EXE file is from HP website "https://support.hp.com/nz-en/drivers...model/22745922"
    original BIN file is in the attached file and photo for SN .
    and serial number : 5cg82504ks
  • Answer selected by hazem3636 at 02-14-2025, 04:46 PM.
    Re: bios for HP "14-cf0001nx"
    Originally posted by hazem3636 View Post
    yes sir this laptop has "Intel Core i7-8550U"
    and i have erased the bios chip and read this same file i get every time ,
    there no way that to use EXE file from HP website and conver it to Bin file by using same serial number of the orginal device
    Try this BIOS, it's a Virgin BIOS from HP.
      Your backup is corrupt and not the right size.What model is your programmer,are you using a clip or have you desoldered the chip. Did you use Auto-detect or choose the chip manually in the programmers support list
        yes the bin file i guess is corrupted ,
        am using "CH341A" programer , and i have selected the chip manually , recognized by the programmer ، but when i click on read is showing this attached file .
          Your BIOS Chip should be 8MB, so why your .Bin file size is 29MB? Try to read the Chip again correctly (Choose the right Chip).
          Does your device have this CPU "Intel Core i7-8550U"?
          all donations are welcome,
                thanks alot ill try and let you know dear ,
                i did what you have asked me before , now the file size is 8.4 MB please check this file
                  Good, now you have read the file correctly but it's not the Original BIOS, so just try the file which I uploaded in Post #6
                    thank you , thank you sir ,
                    my issue has been solved thanks alot for your effort and for support appreciate your effort .
                    all the best
                      are you using a clip or have you desoldered the chip. Are you using any alternative software, you can try NeoProgrammer,ASProgrammer and Colibri
                        dear @SMDFlea
                        i used this NeoProgrammer "attached file" and solder to the CH341A" programer .
                        and i tried the file from @hardware1 and now it's working good .
                          dear @SMDFlea
                          Happy days
                            all the best
                            It's good to know, You're Welcome.
