Lenovo IdeaPad Gaming 3 16ARH7 LA-M082P BIOS
    If anyone needs the BIOS for this model, I will attach it.
    It is an exported BIOS image from the factory update.
    BIOS works normally.
    Thanks for providing this!
    Would this work at all for the HLG50 LA-M082P as well?
    I'm having an issue where it's not booting up and all the BIOS for it that i can find online are on forums with sketchy paywalls...
      Post your backup, full laptop model and serial number.
        Thank you for your quick response!
        - The full model (I believe) is:
        HLG50 LA-M082P
        Rev: 1A
        2022-01-21
        - What do you mean backup?
        - The serial number I have been searching for for an hour. The sticker on the bottom must've fallen off because it's not there, can't use any of the ways that requires it to boot obviously, and I don't have access to the original box or receipt, and I have completely removed the board and scoured everything, with the exception of pealing off the thin aluminum shielding covering most of the back as it doesn't seem to readhere well....
        The closest thing I did find that could be of use, next to the model number in smaller type on the motherboard is:
        E__:1AQ3
        HLG50 D01
        451AUG38L01
        (and then the MAC address)
        Last edited by 78pinFPC; 02-21-2025, 12:03 PM. Reason: *edited formatting for clarification
          you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
