Re: MSI GL63 (Board 16P51, Rev 1) Laptop - Boot Problem
Hello All,
Well, after a long long time, returning back to MSI GL63 (16P51 Board). Many things were going on in personal life and hence put this board on back burner.
Here are the things done so far over last 3 - 4 days -
removed all power sources and power drained board.
removed and replaced CMOS Battery. The existing battery was showing 1.59 volts and thus had become a dud. Now the battery shows about 3.3 volts in circuit.
after reconnecting CMOS battery, pressed reset switch for 10 seconds to reset EC chip to factory setting.
Powered the board. Following points observed -
The Charging led lights when Battery is in the circuit.
HDD led lights up when SSD is installed.
The power button light is RED in color as it should be, when the machine is booting normally.
All keyboard characters led (RED) turn on.
CPU warms up well and the CPU fan kicks in when the CPU temp sensor detects the set temperature.
GPU also warms up well, however, the GPU fan DOES NOT KICK IN. But in this machine, there is integrated Graphics with GPU Assist for gaming.
The issue that I am facing now is NO VIDEO. No display on internal flat panel and no VIDEO output on HDMI port. I connected HDMI port to my TV expecting that I may get video signal; which will indicate issue with panel/video cable.
Also observed following -
The CPU VCORE shows 0.8 Volts indicating that CPU power supply is working to a large extent.
The GPU VCORE shows about 0.8 to 1V and thus even that seems to be within specs.
3.3 Volts and 5.2 Volts supplies are present.
1.05V, 1.5V supplies for memory are present.
So seems like the power supplies are functioning.
I also removed memory sticks and SSD to try and see whether I can get the standard BIOS "Bootable Device Not Found" or "Memory Error Beeps". No luck in the sense that the BIOS routine may be displaying appropriate messages but, because of Video issue the messages are not visible.
I also checked the voltages around 8 pin BIOS chip. 5 out of 8 pins showed about 3.37 Volts when the board was powered on. To me that looks kinda odd. However, I will try to get the exact pins and voltages tomorrow morning and post here.
Requesting all to share your thoughts and guidelines that can help me to figure this issue.
Warm Regards,
Hello All,
Warm Regards,
