HP Envy 17-j053ea dead. What to look at next?
  • rich555
    • Nov 2022
    • 7
    • uk
    HP Envy 17-j053ea laptop. The only sign of life is the power LED.
    I've taken out the power button and the ribbon to the mainboard that that checks out ok.
    No obvious burnt components.
    Not sure what to look at next.
    The machine was working 100%, switched off, 2 days later, dead.
    I've had the memory and motherboard out and reseated all the ribbons and connectors. Still no dice.
    I'll check whats on the DC power connector on the motherboard.
    Just wondering if there is a hall effect device on the power switch board that detects the lid being closed and if this failed, would the machine fail to power up?
    • 21936
    Re: HP Envy 17-j053ea dead. What to look at next?
    Test and post the voltages on all large square grey coils
    Beginner's guidelines https://www.badcaps.net/forum/showthread.php?t=88758
    • rich555
      • Nov 2022
      • 7
      • uk
      OK, will do. Thanks.
      • rich555
        • Nov 2022
        • 7
        • uk
        Had a poke around with the scope. 20v is present at the mainboard connector. 2.8v on the nearest inductor. nothing on any of the others.
        There is 3.3v on 3 of the pins on the power switch connector (6 pin).
        When I press the power button, pin 1 pulses once, for 1ms.
        Pin 2 stays at 3.3v
        Pin 3 goes to 3.3v and stays there for 6.7 seconds then drops back to zero.
        Pin 4 sits at 3.3v and drops to zero for as long as the button is held down.
        Pin 5 sits 3.3v
        Pin 6 sits at zero.
        I assume there is a signal to the PSU to start up and for some reason its not starting.
        • mon2
          • 14677
          Post any pics with silk screen markings on the logic board with hopes we can locate a schematic. Not impossible to repair without one but saves time if possible.
          The 20V is likely from the DCin connector and then there should be 2 x DCin mosfets.
          These mosfets will be enabled via the gate pin # 4 of each by the ACDRV of the charger IC. We need to know which charger IC is onboard.
          The 3v3 you are measuring could be the always on rail (or not).
          • rich555
            • Nov 2022
            • 7
            • uk
            The battery charger is a BQ738.
            I assume there is a chip than manages the power button and fires up the main psu? I have found plenty of Ti voltage regulators scattered around.
            The mainboard has This on the silkscreen: Dynamic KM-VO E25540094V 1346K if that helps.
            • rich555
              • Nov 2022
              • 7
              • uk
              on the underside, the mainboard has: 17SBGV2D-6050A2549801-MB-A02
              • rich555
                • Nov 2022
                • 7
                • uk
                Found schematics for HP Envy 15SBGV2D-6050A2548101 and it looks to have a lot of the same parts.
                There's a nice power up sequence chart and a block diagram of the power supply.
                Got something to go on now!
                  HP ENVY ENVY Desktop - 750-510 ENVY 750 i5-7400 Specification for Upgrade or Repair
                  This specification for the HP ENVY ENVY Desktop - 750-510 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-510 boardview and ENVY ENVY Desktop - 750-510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-12-2024, 03:44 PM
                  HP ENVY ENVY Desktop - 750-524 ENVY 750 i7-7700 Specification for Upgrade or Repair
                  This specification for the HP ENVY ENVY Desktop - 750-524 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY ENVY Desktop - 750-524 boardview and ENVY ENVY Desktop - 750-524 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                  This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                  09-06-2024, 12:18 PM
                  HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) Specification for Upgrade or Repair
                  This specification for the HP ENVY x360 ENVY x360 Convert15-dr1013na 7PW22EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert15-dr1013na 7PW22EA boardview and ENVY x360 Convert15-dr1013na 7PW22EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-06-2024, 11:17 AM
                  HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                  This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
