Lenovo YOGA 900
  • sauce
    • Sep 2013
    • 149
    • France
    Lenovo YOGA 900
    I have a dead motherboard of a Lenovo YOGA 900-13ISK (NM-A411)
    Does anyone know if a NM-A921 is fully compatible (for a YOGA 900-13ISK2) ?
    Everything seems the same except a more recent CPU.
    Thanks.
  • sauce
    • Sep 2013
    • 149
    • France
    Re: Lenovo YOGA 900
    So i found a dead motherboard for my model.
    With this motherboard the fans spin but black screen.
    I do not have the EDP_VDD_EN_R voltage. CPU / GPU dead ? How to be sure all others voltages are present.
      • 21844
      Re: Lenovo YOGA 900
      Check voltages on all large grey coils. Search the forum for the schematic, and look for a power sequence or power block and test all voltages to see whats missing
      • sauce
        • Sep 2013
        • 149
        • France
        Re: Lenovo YOGA 900
        It seems I have not checked GFX_CORE I will try to check it.
        I have the schematic.
        • sauce
          • Sep 2013
          • 149
          • France
          Re: Lenovo YOGA 900
          So here are the voltages of coils near CPU :
          PL16 : 0.902VDC
          PL25: 1.09VDC
          PL26: 0VDC
          PL29: 0VDC
          PL27: 0.97VDC
          So no GFX_CORE.
          What could I test after that ?
          • Sephir0th
            • Oct 2020
            • 1289
            Re: Lenovo YOGA 900
            You can ignore GFX_CORE since it will only show up under load. If the display circuit still doesn't get enables, I'd proceed with a known good BIOS, also check resistance to GND of EDP_VDD_EN_R. If you're out of luck you're dealing with a bad PCH failing in the late sequence here.
            FairRepair on YouTube
            • sauce
              • Sep 2013
              • 149
              • France
              Re: Lenovo YOGA 900
              EDP_VDD_EN_R to GND is 66k
              Just replace ISL95857HRZ because it was the only common thing and now GFX_CORE is 0.480VDC.
              But still no display
              • Sephir0th
                • Oct 2020
                • 1289
                Re: Lenovo YOGA 900
                It is not normal that you can catch voltage at GFX_CORE so if you can (always) measure voltage there now, I really have to assume you made the issue worse. Since you decided to go the random way instead of following what was advised I also cannot assist here anymore.
                Good luck
                • sauce
                  • Sep 2013
                  • 149
                  • France
                  Re: Lenovo YOGA 900
                  Sorry but I replaced the chip before I read your message
                  • Sephir0th
                    • Oct 2020
                    • 1289
                    Re: Lenovo YOGA 900
                    That's another story then and sorry for my rude comment.
                    If the board deasserts PLT_RST# is usually a good indicator whether it is should be ready to P.O.S.T., ruling out a corrupted BIOS is the next logical step then.
                    Do you trust 100% in your soldering of the VRM controller?
                    • sauce
                      • Sep 2013
                      • 149
                      • France
                      Re: Lenovo YOGA 900
                      I think I will resolder the VRM controller it was quite hard to solder
                      CPU core is still 1V.
                      Just test the bios CHIP of the donor board no success the fans not spin at all.
                      I resolder the original the fans spin.
                      Tomorrow I will try to resolder this VRM controller and I will tell you...
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Re: Lenovo YOGA 900
                        In my experience, if gfx core remains constant readable voltage on SOC platforms, its bad cpu.
                        • sauce
                          • Sep 2013
                          • 149
                          • France
                          Re: Lenovo YOGA 900
                          Ok even if I have the caps lock that works ?
                          • Sephir0th
                            • Oct 2020
                            • 1289
                            Re: Lenovo YOGA 900
                            No, when Capslock LED responds (on external Keyboard) the board does indeed the P.O.S.T.
                            You're troubleshooting "just" a no picture issue from here.
                            • sauce
                              • Sep 2013
                              • 149
                              • France
                              Re: Lenovo YOGA 900
                              I do not have the tools to program bios
                              But i with donor bios it does not work (no fan spin) and when i put original it works (fan spin, caps lock ok...), does it mean the bios is ok ?
                              • sauce
                                • Sep 2013
                                • 149
                                • France
                                Re: Lenovo YOGA 900
                                Just another question does screen needs to be plugged to test EDP_VDD_EN_R ?
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Re: Lenovo YOGA 900
                                  Of course not
                                  • sauce
                                    • Sep 2013
                                    • 149
                                    • France
                                    Re: Lenovo YOGA 900
                                    Anyone knows if Fn+R method to flash bios works on this model ?
                                    And what is the bios name to put on USB drive ?
                                    • sauce
                                      • Sep 2013
                                      • 149
                                      • France
                                      Re: Lenovo YOGA 900
                                      I managed to program the bios with my rasperry pi but still fan spin and no display.
                                      I have no more ideas
                                      • Sephir0th
                                        • Oct 2020
                                        • 1289
                                        Re: Lenovo YOGA 900
                                        As we had already told: when CapsLock is reacting the BIOS should be fine and you´re challenging a "no-display" issue then. i think nobody suggested to mess with the BIOS so i don´t know what you try to archieve here.
                                        you should put the original dump back to the motherboard and take a closer look to the voltages at the display connector, so enables, 19V, 3.3V and so on. Or even better: take the board to a serious repair shop.
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:00 AM
                                          Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
