Acer Aspire F5 573G da0zasmb8d0 rev d no power when i measure the volt on the curent resistor i found 3.4 volt on the two sideswhile connecting charger also the charger volt is 19.5 volt
Acer Aspire F5 573G power issue
Re: Acer Aspire F5 573G power issue
1) link a schematic if available
Perhaps the same as yours?
https://www.badcaps.net/forum/showth...ht=da0zasmb8d0
2) what is the charger IC onboard ?
3) review the input DCin mosfets from the DC adapter to the current sense resistor you are measuring. Check the resistance (with NO power) of:
source (1-2-3) & drain (5-6-7-8)
source (1-2-3) & gate (4)
gate (4) & drain (5-6-7-8)
4) Remove all power -> measure the resistance to ground of the current sense resistor you are measuring -> if the resistance is low, there could be a shorted component on this main power rail causing this 19v to be so low.
Or the fault could be that the DCin mosfet is defective and not allowing for the power path for the 19v onto the main voltage rail.
Update:
See attached -> review each of the referenced parts and arrowheads. Start with the diode @ PD3 - what is the voltage BEFORE this diode and AFTER this diode - connect your external adapter (remove your battery).
Need to play a plumber to fix a leaky faucet with a stripped allen screw..bbl.Last edited by mon2; 10-10-2022, 09:59 AM.
Check if the Vcc is ok on the charger IC without this bypass. Also check REGN pin. Both are common test points for this 'BQ' series of charger ICs to build the boosted ACDRV voltage.
The Vcc rail is fed from the raw DCin adapter and often through a dual common cathode diode (one from the DCin; other from the battery feed).
If you have such a dual diode (sot-23 package) - check if perhaps this diode is defective.
